QUOTE(Dave_Darling @ May 18 2014, 12:01 PM)
QUOTE(malcolm2 @ May 18 2014, 08:10 AM)
Being that my wheels are not stock and they are ATS, I am assuming that the wheels take conical lugs.
DO NOT ASSUME!Seriously, this is stuff that can kill you. So do not assume the DAPO did it correctly, especially when it takes all of three minutes to remove a lug bolt and actually look at the wheel.
Please check. At the very least, it could keep another 914 from being wrecked.
--DD
All I can do is assume. I have put 3500 miles on this car with the concial bolts that came on it. So they seem to be holding the wheels on at speeds up to 70mph.
That is why I would like to see a picture or some measurements of what other ATS owner's bolts look like. I don't think my current conical bolts are correct. It is obvious that the picture of the conical NUT above and my ATS conical BOLT do not have the same geometry. I ASSUME, I need to find a conical bolt like the conical nut above. They come in all kinds of sizes, I know that for sure, so which ones should I buy. Can you help with that?
It is not easy to see for sure (hence "I assume" was used) and it is tuff to measure the cone dimension on the wheel, but it is coned. I get 75 degrees on the bolt (also tuff to measure) and the TOP of the cone is no wider than the 19mm hex, UNLIKE THE NUT pictured above. Is that an OK assumption?
