Hey, there's probably a better way to do this, I'm open to hearing it,
but I saw this 10lb motorcycle battery on clearance for $8 and had
to get it. Made up a safe bracket for it.
Since I got the Optima (the bigger one which is 40lb), I've thought
I need to save some weight for AX, and you can't do much in stock
classes, but they don't specify what you have to run for a battery.
Surprsingly, this thing will start up the -6. But I plan on only using it
while the car is warm so as not to kill it prematurely.
Of course I need to lose 25lbs too, but it ain't gonna happen this
easily
Mark S.
'70 914-6
