lapuwali
Jan 16 2005, 05:24 PM
Finally get around to fixing a pulled exhaust stud, get everything buttoned up, quick test drive. Back into the garage, check all of the exhaust nuts. Long test drive.
Runs OK for about half distance, then it sounds and feels like it's losing a cylinder. Thudding exhaust note and no power. Up a steep (unavoidable) hill, it starts what sounds like really loud ping under load. Goes away when I get off it, and stays away if I keep the speed down up the hill. CHT on No. 3 isn't higher than usual (about 340 up that hill, about 300 on the flat). Nearer the house, it idles OK, but doesn't pull away from a stop w/o a fair amount of clutch slip. No odd noises.
Sigh.
Haven't the time to pull everything apart to take a good look this weekend. This engine has been trouble from the word go. I've had maybe 50 trouble-free miles in the last 6 months.
I'm beginning to think a Soob conversion isn't an option, but a requirement. No way I'm going to spend serious money on this engine...
brp914
Jan 16 2005, 06:17 PM
We feel your pain, cuz we've all felt our own. I've seen many of your responses, I know you'e a smart guy and can figure it out. Gotta be something simple - vacuum, ign timing, compression...?
jwalters
Jan 16 2005, 06:29 PM
Sounds like your dizzy is stuck in full advance---
redshift
Jan 16 2005, 08:31 PM
If the dizzy spins... Check it, peep!
If anyone can empathize, it's me.
Just do the standard thing, completely rebulid your motor each time it needs a valve adjustment.
M
Bruce Allert
Jan 16 2005, 11:01 PM
Put a cover over it and stay away for a couple days. That's what I had to do. I even listed it for sale
I was pissed. Had a full weekend planned going on a wine tasting cruise with the Bro N law & his Boxster. Damn Punkin began running like shit right after I washed it.
Dug back into it the next week & found a bigassed bandaid to make it run good. Been running good ever since.
Now that I said that it'll run shitty tomorrow
.....b
SpecialK
Jan 16 2005, 11:51 PM
QUOTE (jwalters @ Jan 16 2005, 04:29 PM) |
Sounds like your dizzy is stuck in full advance--- |
First thing I thought reading your post.
tesserra
Jan 17 2005, 12:12 AM
Distributor loose and spun too advanced.
I burned up a type I by not tightening the dizzy after a tune up. Put a hole in the piston.
lapuwali
Jan 17 2005, 01:17 AM
Good theory. Nearly new Mallory Unilite on this engine. It's clamped down pretty tight (can't move it by hand), but I haven't checked with a timing light to see if the advance is still where I set it (11d at idle, 32d at max).
It does get frustrating. It's never been the same problem twice, always something new. Car is cursed.
DJsRepS
Jan 17 2005, 05:10 AM
Take the advance plate out for a lube job. Check the vac adv unit, and the trigger points while its out. Then FI harness and grounds. My FI had 3 terminals with green colored copper wire. You could hardly see it untill you loosened up the insulation clamp of the terminal to tug on the wire conection. One of mine fell off at this point. Check vac leaks hoses and MPS and Vac adv and ohm uut the TPS for the idle pos. Loose the points to Petronics. If you were having some noise issue it would not hurt to adj and check the valves and compression.
markb
Jan 17 2005, 08:29 AM
QUOTE (lapuwali @ Jan 16 2005, 11:17 PM) |
It does get frustrating. It's never been the same problem twice, always something new. Car is cursed. |
Nahh, it's just a 914. Get used to it.
Mark Henry
Jan 17 2005, 08:47 AM
QUOTE (DJsRepS @ Jan 17 2005, 07:10 AM) |
Take the advance plate out for a lube job. Check the vac adv unit, and the trigger points while its out. Then FI harness and grounds. My FI had 3 terminals with green colored copper wire. You could hardly see it untill you loosened up the insulation clamp of the terminal to tug on the wire conection. One of mine fell off at this point. Check vac leaks hoses and MPS and Vac adv and ohm uut the TPS for the idle pos. Loose the points to Petronics. If you were having some noise issue it would not hurt to adj and check the valves and compression. |
Try reading the whole post before giving advice...
QUOTE |
Nearly new Mallory Unilite on this engine. |
DJsRepS
Jan 18 2005, 06:32 AM
I thought the mallory unite was a coil if thats what you ment. And I did read the whole post. Thaaaank Youuu. And I have seen worse advice. And the Plate is sitll in effect with eletronic ign so is the vac adv. I guess I dont get your point there Mr Mark Henery.
Mark Henry
Jan 18 2005, 06:45 AM
QUOTE (DJsRepS @ Jan 18 2005, 08:32 AM) |
I thought the mallory unite was a coil if thats what you ment. And I did read the whole post. Thaaaank Youuu. And I have seen worse advice. And the Plate is sitll in effect with eletronic ign so is the vac adv. I guess I dont get your point there Mr Mark Henery. |
A Mallory unilite is a dizzy
TheCabinetmaker
Jan 18 2005, 06:54 AM
QUOTE (Mark Henry @ Jan 18 2005, 06:45 AM) |
QUOTE (DJsRepS @ Jan 18 2005, 08:32 AM) | I thought the mallory unite was a coil if thats what you ment. And I did read the whole post. Thaaaank Youuu. And I have seen worse advice. And the Plate is sitll in effect with eletronic ign so is the vac adv. I guess I dont get your point there Mr Mark Henery. |
A Mallory unilite is a dizzy |
Mark Henry
Jan 18 2005, 06:56 AM
James is that Mallory a vacuum advance or mechanical…Jake has had the vacuum advance break or seize in full advance and won’t use them.
If it is a vacuum I think you can remove the vacuum bits.
lapuwali
Jan 18 2005, 09:59 AM
It's mechanical, no vac. The PO had fitted carbs with an 009, and I got the Mallory to try to reduce one potential source of problems. Right now, I'm in the "ignore the car for a bit" stage.
Bleyseng
Jan 18 2005, 10:12 AM
How new are the spark plug wires? How about the coil? Nice bright blue spark if you pull a plug?
