so far, it's been an interesting experience for me to observe.
I notice a few different things.
Now I've done plenty of oil changes in a 914,
since 1985.
Green Machine
My first and still own, 914.
Install EZ, thanks Chris!
I checked the old oil relief SS plug,
It has nasty scoured scratches on it.
Hmmmmmm.
Now I add oil.
Put in what I thought was correct amount,
I've almost a quart over??
well I'm excited to get the engine running,
I can drain it later.
Start her up 70-73 lbs of oil pressure.
Normal.
I let her run for an hour, checking everything,
(Beauty is up on jacks)
Temp. finally gets near 180.
Good enough for me!
And oil pressure is at 40 Lbs! at 1200 RPM idle.
Is this ok?, I'm happy with it.
Now the weird part,
I go drain some oil to get it down to ,what I thought was the proper level,
being under the 914, guessamating about a half quart.
check oil level, no change.
Dang, so I say myself, drain a lot and you can always put it back.
No prob. drain about a quart and some.
Oil level perfect, I have been adding an extra 1/2 qt.
So I go about so with fresh drain, what I thought was fresh oil,
It was BLACK!
I go to strain it thru paper towel (took FOREVER)
nothing,
Well I didn't reuse the oil,
but I think what Beauty has been suffering thru,
was the plug was stuck in cold position, sorta closed off the cooler,
allowing the soots of hot burnt oil build up in the cooler,
as less flow, easy deposit?
I'm not complaining,
I cannot wait to get it on the road for Road test temp.check.
But I'm very busy with work,up till end of year.
