[quote name='3d914' date='Jun 14 2014, 08:09 AM' post='2050058']
[quote name='Emmel' post='2049547' date='Jun 12 2014, 07:20 PM']
Click to view attachmentCan't go wrong with Sata Rp's to lay down the Glasurit base, these guns cannot be topped . Plus using no sealer under the base helps everything lay down that much smoother. Sealer has a tendency to rob the solvents from the base coats and will ultimately orange peel slightly making the Clear coat lay down exactly the same way as the base lays.
[/quote]
Emmel, beautiful job! As a novice I'm confused by your "no sealer" comment. Can you explain? Would that still apply if I wanted a single-stage paint job for everyday use?
TIA
On using sealer it all depends on what sand paper grit you finish with hopefully it's 600 or 800. But sealer is usually fool proof so it helps on those small sand scratches you may have missed . And breakthrough s on the primer so it won't show through the topcoat like bullseyes.Sealer is pricey so I try to do without everytime.
