Trekkor
Jan 16 2005, 10:25 PM
I don't have the temp guage up and running yet.
I can tell you that the oil tank and filter are hot to the touch. I can hold my hand on it but starts to hurt. That hot.
I remember years ago not being able to pull the dipstick on a typeI motor. That
was hot.
What temp is considered too hot?
Safe range is?
KT
Joe Bob
Jan 16 2005, 10:26 PM
180-220 OK
230-240 warm
240-275 hot
275-300 real hot
300+ too damn hot
J P Stein
Jan 16 2005, 10:32 PM
220-230 tops if you want it to live.
Bruce Allert
Jan 16 2005, 10:44 PM
I just picked up an oil temp gauge. Hopefully it will respond with the proper temps from the sender I have.
There are 3 spade connectors on the back of it (a +, a - and an S). Am I correct in my thinking that the "
S" is where the sending unit wire is connected?
Wish me luck!
......b
Aaron Cox
Jan 16 2005, 10:59 PM
QUOTE (Bruce Allert @ Jan 16 2005, 09:44 PM) |
There are 3 spade connectors on the back of it (a +, a - and an S). Am I correct in my thinking that the "S" is where the sending unit wire is connected?
Wish me luck!
......b |
vdo cockpit or a temp in the combo gauge? taco plate sender?
Bruce Allert
Jan 16 2005, 11:05 PM
Aaron
it's a VDO cockpit guage. Sender is in the Taco or that thingy that looks like a tuna can held in by a bolt under the engine NE of the oil drain!
......b
Aaron Cox
Jan 16 2005, 11:25 PM
the sender that is in there is calibrated for the console and the in dash temp gauge.... i believe the cokcpit one is different
DuckRyder
Feb 4 2005, 01:02 PM
Hi,
I have the same questions, did we verify that the sender in the taco plate is wrong for the Cockpit gauge?
Last time I drove the car in warmer weather the gauge was 3/4 of the way to the hot side.
Can I just put a cockpit series gauge in there (change sender yes or no?) and find out how hot, hot is?
I don't really trust the 30 year old gauge! But I'd prefer not to cook a new motor either...
Feb 4 2005, 01:18 PM
QUOTE (J P Stein @ Jan 16 2005, 08:32 PM) |
220-230 tops if you want it to live. |
~200 is optimal, over 230 is too hot ...
Andy
jr91472
do a search.
wasn't long ago, but someone posted a table of compatible senders and guages.
machina
Feb 4 2005, 01:33 PM
I called VDO USA. They actually make several temp probes in the 150deg C range.
To be sure, I am going to remove my sensor and place it in boiling water with a known good manual thermometer and then calibrate the electric gauge.
Boiling point for H2O at sea level is 212 deg F.
Trekkor
Feb 4 2005, 01:36 PM
Checked several hot spots with the pyrometer yesterday after hotting it up.
oil filter 194
oil tank 160
oil inlet to cooler next to header 204
It's currently wired to stock temp guage in console, reads at "P" in temp swipe. Same as hot FOUR.
Someday I'll finish the wiring.
KT
Aaron Cox
Feb 4 2005, 01:39 PM
sounds like you could use one of these.....
JK....shameless plug..AA style
Trekkor
Feb 4 2005, 01:45 PM
Already got one of these...
Aaron Cox
Feb 4 2005, 01:46 PM
QUOTE (trekkor @ Feb 4 2005, 12:45 PM) |
Already got one of these... |
what about a gas gauge?
Trekkor
Feb 4 2005, 01:48 PM
Ordered one of these for the console in place of the temp guage...
Dave_Darling
Feb 4 2005, 01:49 PM
Bruce Anderson says, of the 911 motor--
230F is hot.
240F is very hot.
250F is TOO DAMN HOT.
Synthetic oils can withstand high temps better than old-fashioned "dinosaur" oils can. But heat has other bad effects on the engine, so keeping it under 250F is pretty mandatory IMHO.
...You are talking six-cylinder, right Trekkor?
--DD
Trekkor
Feb 4 2005, 01:59 PM
QUOTE |
You are talking six-cylinder, right Trekkor? |
Oh, yessss
machina
Feb 4 2005, 02:01 PM
And here is what Jake says...
180-225 is perfect..
225-245 is very warm and will require oil changes more frequently as it heats up the oil and breaks it down faster
250+ is very hot- Shut her down unless you have a pressure gauge and can ensure that you still have atleast 40 pounds of operating pressure.
Hot oil is thin oil... thinning out the oil is what spins bearings and wears parts.
Oil temps are directly related to RPM and ambient air temps.
