Have your local FLAPS (Friendly Local Auto Parts Store) to lookup the pump for your car.
It should provide some entertainment
These cars did not have pumps.
In the front trunk is a line that connects to the spare tire and pressurizes the washer fluid tank.
The cap of the WW fluid tank should have a nipple on it that has this tube attached.
If it is there, fill up the fluid, connect the hose to the spare tire, then immediately check under the dash for any fluid leaking.
If not, try the squirter valve.
I think it is pull the washer switch , but I dont know for sure as I have never had a car where this worked.
Other than that, there are aftermarket pump upgrades you can get.
Someone on here will post the link by the time I get done typing:
AND
