scotty914
Jan 19 2005, 10:54 PM
okay got the engine bar for the suby almost done, it measures 1 inch square wall thickness .083. with 16 gauge gussets. right now i can lean on the ends and it flexes about 1/2 inch ( 190 lbs ) i will be welding a 90 degree angle on two side after i fit it to the car and engine.
not bad for gas welding
scotty914
Jan 19 2005, 10:55 PM
gusset detail shot
RS22b
Jan 19 2005, 11:20 PM
nice!
Interested in seeing what you have when you're done.
-billy
McMark
Jan 20 2005, 11:41 AM
Looks good. Can't wait to see it in the car.
Yay, gas welding. MIG has its place, but I prefer gas for most everything.
mattillac
Jan 20 2005, 01:44 PM
excellent progress scott. i'm very anxious to see the end result. keep up the good
work.
Chris H.
Jan 20 2005, 11:00 PM
Nice work Scott. Once you get your engine mount setup perfected let us know if you want to make a few more of them!
scotty914
Jan 21 2005, 05:00 PM
well just stuck the engine bar under car looks like its perfect, you can see where the motor mounts are ( circled in white ) i just need to shorten the tops, right know they are about 8 to 10 inches too long.
tonight i will build the part that bolts to the motor mounts on the engine
a couple of pics
scotty914
Jan 21 2005, 05:02 PM
now for a close pic of motor mount to bar, remember it needes to come up a few inches, also notice how most if it tucks behind the head. it will not be in the way of exhaust or shifter, as well as it clears the trailing arm
scotty914
Jan 21 2005, 05:04 PM
and last one showing here the body mount will go and where the top of the bar is before i shorten it
scotty914
Jan 21 2005, 07:29 PM
here is a pics of the bar that will be welded to the engine bar and bolted to the stock engine mount on the motor
its made from 2, 1/8 thick 1 inch angles welded together, with a solid peice welded across the two where the bolt goes
