914Sixer
Jul 13 2014, 09:37 AM
I am trying to get the 75 up to speed so I can get it inspected. I noticed the horn pad was not setting right so I went ahead and ordered the horn cuff. Well this morning I went out to put it in. Sure enough the old one had collapsed. Put the new one on and the horn pad was still off. I double checked everything , the scratched my head. Got another horn pad and it did the same thing. The steering wheel hub did not look right, It took a comparison of the horn pad and the steering wheel hub to figure it out.
DAPO's ????
Krieger
Jul 13 2014, 11:02 AM
Yikes! Time to check the engine/ tranny bolts, suspension and other steering bolts.
Old Yella
Jul 13 2014, 11:27 AM
The tab has not been filed off. That's normal. Which way are you putting the the horn on. Left to right or right to left?
914Sixer
Jul 13 2014, 04:52 PM
After the pictures of the wheels from Ole Yella, I went back to the garage and started over. The tabs on the hub are all bent up as shown in the pictures. It took 5 hubs until I found one that would work.
Dr Evil
Jul 14 2014, 09:45 PM
Missing circlip on shaft causing all things to be tightened too far down?
