Full Version: Flare your steel rockers.
Series9
Here's a pretty simple way to flare your steel rockers. They come out pretty nice.
13 pictures to follow:
Start by marking a line on the rockers that matches the flare on the car:
Series9
snip the top and bottom lips:
Series9
Remove this extra metal from the front bottom:
Series9
Bend along the lines:
Series9
Bending the rocker outward creates a gap at the top:
Series9
another:
Series9
Cut some metal and put a 90 degree lip in it:
Series9
Filler piece in place. Scribe it's shape on to the rocker and cut along the lines:
Series9
Prep for welding:
Series9
Say hello to my little friend:
Series9
IPB Image
Series9
Mark the fender arch and cut:
Series9
Last one.
Cut out some metal to make an end cap and weld it up:
The body man will give them a little beating to soften the bend.
Series9
The V cut at the bottom is welded now as well.
The real last one:
Series9
Third last one.
Here's the DS rear on the car, basically finished:
spare time toys
Nice job
John
This is EXACTLY why I'm making up steel rocker panel shapes with blank ends. $45.00 each side.
Non-stock steel rocker panels
BIGKAT_83
Thanks for going to all the trouble to write this up. Ill start on mine next week.
I see a classic thread in the making.
Bob IPB Image
maf914
Joe, Good job. Your car looks great and is coming along very nicely.
Thread Hijack!
Joe, I know you've described your wheel/tire combo before, but I can't seem to find the thread. Could you please describe the wheel size, tire size, and spacer size you've used? Thanks.
Gint
Really nice Joe.
Series9
QUOTE (maf914 @ Jan 24 2005, 07:12 AM)
Thread Hijack!
993 Cup II factory wheels: 7x17 fronts with 225/45-17s and 9x17 rears with 255/40-17s.
At each corner: 100mm wheel studs, 42mm spacers (2x21mm early 944 rear spacers) and steel lug nuts.
maf914
Joe, Thanks for the info. That's a lot of wheel and tire! Sure is pretty. IPB Image
Lou W
Very nice, Joe tell me about "your little freind", model, size, etc. Did you do all or most of the welding on your car with it? IPB Image
Series9
QUOTE (Lou W @ Jan 24 2005, 03:01 PM)
I did all the welding on 914RS with the welder which was previously pictured.
It's a Lincoln TIG Squarewave Pro-175. Purchased online for around $1400(delivered) + $150 for the argon bottle (150 cu. ft), $50 to fill it, $150 for an auto darkening helmet and a few other pieces here and there.
I can weld steel, aluminum and stainless with it and it's probably my favorite tool EVER.
