Pelican tech notes had this-
I did have some problems getting the hub with new bearings and rotor back onto the spindle. It transpired that the inner bearing was not sitting snugly in the inner race which made it impossible to get the hub onto the spindle. Make sure the greased inner bearing is sitting snugly in the race before presenting the hub to the spindle.
Then they suggest slightly tapping the hub with a hammer to get it onto the spindle.
Here is another article-
http://forums.pelicanparts.com/porsche-911...e-question.htmlMake sure your spindles are clean.
Put the hubs with bearings installed out in the sun for 20 minutes
Blast the spindles with some cold spray or pack them with ice while the
hubs heat up, then try installing.
