ChrisReale
Jun 1 2003, 04:29 PM
Took out dizzy to clean up Trigger points.
Didnt mark anything. Got TDC with the white mark on the impeller. Put dizzy back in, car wont start. WTF??
Can anybody walk me through a dizzy installation? I think I am overlooking something that is quite obvious, but I cannot seem to understand it.
ChrisReale
Jun 1 2003, 05:30 PM
Anyone??
seanery
Jun 1 2003, 05:39 PM
what motor?
I've got my Haynes manual out and ready.
ChrisReale
Jun 1 2003, 05:42 PM
I have a Haynes manual also, and it has not helped one bit. Its a 2.0L
I have the white TDC mark in the groove on the impeller. Shouldnt the rotor point to the mark on the dizzy while the motor is at TDC??
seanery
Jun 1 2003, 05:48 PM
I would double check that you are setting it up with Cycl 1 on tdc of the firing stroke. And double check your cap and wires.
I'm lost after that.
my15window
Jun 1 2003, 06:02 PM
rotor needs to point to notch in dist rim, thats #1 plug wire run your finger over the lip where the cap sits and you'll feel the notch..
Gint
Jun 1 2003, 08:35 PM
Could be you're 180 out. If so, you're on the exhaust stoke. The dizzy only goes in one way on a 2.0/4 If I'm not mistaken, the motor turns 2 full revolutions for one revolution of the dizzy. Pull the dizzy again, rotate you engine over JUST ONCE and bring it back to the TDC mark, and install your dizzy with the rotor pointing at its TDC mark. Try that.
Bleyseng
Jun 1 2003, 10:14 PM
Did you put the rotor back in??? Don't ask me how I know about that one....
Geoff
ChrisReale
Jun 1 2003, 10:58 PM
Yea, it was not seated fully.
Got it to idle, but it is not spitting gas on cylinders 1 and 4. I have spark....trigger points I think
