db9146
Jun 13 2015, 03:01 PM
I assume that's a side shifter trans?
I'm going to convert from tail to side shifter and looking to understand the parts needed.
EdwardBlume
Aug 22 2015, 09:07 AM
Dropped the top off at Yeoman. Wanting to put the interior back in today. Just need to figure out the interior light.
EdwardBlume
Aug 22 2015, 09:08 AM
Some nice bling....
EdwardBlume
Aug 22 2015, 09:10 AM
Some nice bling.... Thanks Spoke!
EdwardBlume
Aug 22 2015, 09:41 PM
Interior done save the CDR 220 face plate on back order.
EdwardBlume
Aug 26 2015, 09:55 PM
Getting closer....
The right accelerator cable is installed (installed a /4 then a /6 cable) there is some cable slop though. Is there a way to tie a knot or something.
Adjusted the clutch. Seems to be OK.
Brakes are squishy to the floor but then become OK if pumped. Might need a flush.
Roof is at Yeoman's
Got the 911 Oil Breather Hose in the mail, but need some big clamps...
Time to start?
lonewolfe
Aug 27 2015, 12:48 AM
QUOTE(RobW @ Aug 26 2015, 08:55 PM)
Getting closer....
Roof is at Yeoman's
Time to start?
Probably a dumb question but who or what is Yeoman's?
EdwardBlume
Aug 27 2015, 08:09 AM
QUOTE(lonewolfe @ Aug 26 2015, 11:48 PM)
Getting closer....
Roof is at Yeoman's
Time to start?
Yeoman is a Porsche ish body shop in Palo Alto, that can shoot targa tops and refinish them.
Scott has a /6 and a couple tube frame 914s.
matthepcat
Aug 27 2015, 08:27 AM
It's actually Yeaman Auto body. I got my previous car repaired there.
EdwardBlume
Aug 27 2015, 08:56 AM
QUOTE(matthepcat @ Aug 27 2015, 07:27 AM)
Its in EPA right next to 101.
EdwardBlume
Aug 30 2015, 07:03 PM
Oil breather hose. Does this look right to you?
EdwardBlume
Sep 20 2015, 04:48 PM
Radio done.
EdwardBlume
Oct 11 2015, 07:18 AM
Update:
Mounted the exhaust clamps by extending the bolts off the back of the transmission.
Tightened the accelerator cable and straightened the cable angle.
Added oil.
Added fuel.
Turned motor.
Distributor wasn't assembled right and was loose - too much play.
Changed out Petronix back to points and condenser.
Plugs were fouled and were finger tight. Installed new plugs and tightened them.
MSD was wired wrong. Took 2 hours to figure out and fix. Was set up for an 8 cylinder.
Got fuel pressure but the PO had piped 2 filters and pressure gauge. Showing 3 lbs at the gauge but I am going to eliminate the second filter.
Motor started hard after significant effort but not for long. Carbs have big venturis for 40s and don't seem to match a 2.4. Pulled the carbs and sent out for a cleaning / rebuild.
Cairo94507
Oct 11 2015, 07:27 AM
Wow! I can not wait to see your car.
EdwardBlume
Oct 11 2015, 07:49 AM
Thanks. Hope to have it done soon.
EdwardBlume
Oct 24 2015, 06:56 PM
Drove it around the block. Its loud. Distributor is wrong. Going to have to send it out to synch up with a 2.4 with carbs.
Alternator is shot too. Only getting 13 volts when revving and the gen light is on.
Nothing like getting done... only to have to pull the motor.
EdwardBlume
Oct 24 2015, 06:59 PM
Here she is...
EdwardBlume
Oct 24 2015, 07:00 PM
lonewolfe
Oct 24 2015, 07:09 PM
What a beautiful car!
EdwardBlume
Nov 1 2015, 05:59 PM
I need to pull the distributor, but it won't come out. I have it at TDC #1, with the rotor pointing at 1. Took the bolt off the adjuster and can move it back and forth, but it will not come up and out. Any ideas?
kconway
Nov 2 2015, 03:11 PM
New seals...gotta pry it out.
Mike Bellis
May 8 2017, 10:46 PM
Motivational bump. Get this thing on the road!
EdwardBlume
May 9 2017, 02:31 PM
QUOTE(Mike Bellis @ May 8 2017, 09:46 PM)
Thanks. I just picked up a 3.0 for it...
mtn flyr
May 13 2017, 09:59 PM
Click to view attachment Looking forward to seeing another flared Alaska Blue one!
pete-stevers
May 13 2017, 10:15 PM
A very fine specime!!!
EdwardBlume
May 13 2017, 11:50 PM
QUOTE(mtn flyr @ May 13 2017, 08:59 PM)
Nice!
Now you're just bragging!
EdwardBlume
Dec 26 2018, 05:23 PM
Here she is at Rennsport Reunion VI.
Turned out the distributor was off a couple teeth and a bunch of other stuff. The car is fully sorted for safety but needs some rework on the carb side to get it dialed in. New tires eventually, a proper front valence, and a parasitic battery drain. Short list.
Actually considering selling in 2019. I want to build another car.... stupid hobby.
914 Ranch
Dec 27 2018, 01:58 AM
"I want to build another car."
rgalla9146
Dec 27 2018, 06:40 AM
QUOTE(914 Ranch @ Dec 27 2018, 02:58 AM)
Post some ABM 'before' pictures.
EdwardBlume
Dec 27 2018, 12:52 PM
QUOTE(rgalla9146 @ Dec 27 2018, 04:40 AM)
It’s an original ABM with a new paint job post metal flares. The PO’s picts are mostly the motor and parts. When I got it, it was non-opt, non-running, nothing connected, with most of the parts including the interior in boxes. Sad to say it took 4 years but there you go.
The PO said it was a Slits motor. It’s a 73.5 7R 2.4 but I have no idea if it has a stock cam or any valve / head work. The carbs are getting it going but it’s sucking gas and power seems to be at 75% at certain points. Pretty looking though with shiny parts!
I picked up a zero mile 3.0 but that’s a longer adventure....
I have an opportunity to build a real dream 914....
euro911
Dec 27 2018, 02:13 PM
It's a beautiful car
rgalla9146
Dec 27 2018, 02:17 PM
The point being made is that to call this your "build" is a stretch.
The car was 80-90% done when you bought it... in any event, the car looks beautiful and
the work you did got it back on the road. We've all gotta start somewhere... keep it up!!!
euro911
Dec 27 2018, 02:28 PM
EdwardBlume
Dec 27 2018, 02:29 PM
QUOTE(rgalla9146 @ Dec 27 2018, 12:17 PM)
Oh, I get it. It was 80-90% done! That’s funny. If it really was 80-90% done that would have been very nice, but anyone who has put together a conversion car, the percentages can go down with issues that pop up. I should have done a better job of posting more, but there you go....
I want to build a B-24 themed 914 as a tribute to veterans and my Dad. Been searching for a donor car for awhile and may have found a good candidate.
Cheers!
euro911
Dec 27 2018, 02:33 PM
God I hate getting old ... I can't remember his screen name
... but he built a military aircraft themed green 914 several years ago.
I'm sure someone will remember it.
EdwardBlume
Dec 27 2018, 02:42 PM
QUOTE(euro911 @ Dec 27 2018, 12:33 PM)
Thomas?
euro911
Dec 27 2018, 05:44 PM
QUOTE(EdwardBlume @ Dec 27 2018, 12:42 PM)
Thomas?
Not THOMAS. The car was Olive Drab/Army green with black accents and NACA ducts in the hood (IIRC).
I just went through all 168 pages of the 'Member's 914 Pictures, Show us your cars!!' thread and didn't see it there
Dave_Darling
Dec 27 2018, 10:58 PM
QUOTE(euro911 @ Dec 27 2018, 03:44 PM)
IIRC, that's the V8 with a Mendeola gearbox? That was on the Pelican Racing BBS for a while. Don't remember if he made it here or not.
QUOTE(EdwardBlume @ Dec 27 2018, 12:29 PM)
Of course it was 90% done! Of course, then you have to do the next 90% of the work, and then that leaves only 90% of the work to go....
--DD
EdwardBlume
Jun 24 2019, 10:18 PM
Still working on my 90% done car.
Newer battery is putting out 16+ volts at rest. Took it for a drive and the stock volt meter is pegged at 12 until I use any light. Headlights on pegs it to the left.
Battery lasts about a week before its drained.
euro911
Jun 25 2019, 12:18 AM
Finally - found the car I was referring to. It belongs/belonged to Tim, (
@byndbad914 )
EdwardBlume
Jun 25 2019, 06:42 AM
QUOTE(euro911 @ Jun 24 2019, 11:18 PM)
@byndbad914 )
Click to view attachmentWow. That is cool. I had a different concept, but have given up on it. The rock bands are taking all my time now.
