I redesigned the worm support block after the testing the first prototype.
The first unit had a support pin in the center of the worm but it was only held from the bottom, which created too much backlash.
Now it rides in a 3/8" dia. pocket just large enough for the worm to turn without noticeable free play.
Here's a pic of the second prototype installed under a Rennshift.
Click to view attachmentInstallation only takes a few minutes but does require the shifter to be removed from the tunnel.
Adjustment was very easy even though the Rennshift adjuster opening is rather small.
After getting the lever fore-aft position set by sliding the gear on the shaft, I put it into 3rd gear and pulled it back out partway (onto the synchro) so I had good access to both the clamping bolt and the adjuster.
Then I loosened the clamping bolt and rotated the gear until the lever was exactly midway in the center plane, and re-tightened the bolt.
All 6 gears go in smoothly with equal spacing between the three planes.
I'll drive it to check the alignment in operation, and if a slight re-adjustment is needed it'll take about one minute.
