siverson
Oct 5 2014, 03:57 PM
whats the latest thinking on these. should they be bolted and welded in?
-steve
Mblizzard
Oct 5 2014, 04:23 PM
For me it depends on how you will drive the car. If you are just a person that occasionally drives the car hard then bolt in is fine. If you are going to auto cross every weekend then you would want to weld and add some of
Madddogs Motor Sports reinforcement mounts. Very nice stuff that works very well.
McMark
Oct 5 2014, 04:32 PM
They only need to be tack welded so you can remove the bolts without the plate falling.
toolguy
Oct 5 2014, 04:49 PM
Weld them in. . and I'd do a little more than just tack weld them. . .
I've ripped out the factory welded plates on 2 914's and 1 911 from
aggressive turns in slaloms and time trials. . .
Think about this. . if you're lifting a wheel in a turn, all that front force is on the sway bar mounts. . that's a whole lot of force. . more than a few hundred pounds. . and that sheet metal is relatively very thin.
messix
Oct 5 2014, 05:05 PM
i believe that the factory welded them on. and they installed them on the outside in the wheel well.
i don't see any reason to do it differently than what some German engineers did...
EdwardBlume
Oct 5 2014, 05:10 PM
QUOTE(McMark @ Oct 5 2014, 03:32 PM)
McMark posted a thread on installing a sway bar mount at one time...
76-914
Oct 5 2014, 05:52 PM
Weld 'em. You can't access the entire flange on the inside without major cutting so a large tack weld is all I could achieve.
ChrisFoley
Oct 5 2014, 07:26 PM
Depends on sway bar size and the kind of driving done with the car.
Any track car with a larger than stock bar should have them fully perimeter welded.
A street car with a stock anti-sway bar is fine with them tack welded in place.
IMO those triangular plates have a poor shape for the location, and the plating will interfere with making quality welds.
siverson
Oct 7 2014, 11:51 PM
thanks for the tips. i think ill just weld the edge as much as possible without cutting any more. this is for my stock 914-6 with 2.0 motor, street driven, 185 tires, tarrett 22mm sway bar.
-steve
arkitect
Oct 19 2014, 06:22 PM
QUOTE(RobW @ Oct 5 2014, 04:10 PM)
Can anyone point me to the thread mentioned here that McMark did?
Looking for picts of front sway bar install. thanks.
Dave
infraredcalvin
Oct 19 2014, 11:37 PM
