QUOTE(yeahmag @ Oct 28 2014, 10:06 PM)
I'm running roller bearings on the rear now and can only assume that running toe in will be hard on the roller bearings on the "face" of the kit. I'm concerned that as I toe it in it will only run on a few of the rollers and at an angle to boot...
I have it shimmed so that there is no discernible play, but may need to loosen it up a bit as one of the bolts is trying to work free on occasion.
Any words of wisdom?
This has always bugged me about the basic design of the trailing arms.
I think a self leveling solution on the outer mounting side would be the answer.
I use them on my front a-arm mounts to eliminate some binding due to the mounts being slightly deformed.
Not sure if anyone makes those in the size needed for our trailing arms, but the basic design is a conical(ish) piece that can rotate freely in a cup.
