I have over $28K invested in this car. I have mainly auto-crossed it, and focus has been on performance. Mechanically, it is very sound. This car is set up for continued auto-cross or for just a fun, fast canyon carver. It has been loads of fun with many trophies to show for the effort. The interior has been put back to stock, except for the gauges. (See photo) The original 75 bumpers are available. They would go with the car if wanted.
$14,000 – Please, serious offers only.
There are 132,905 original miles on this 3 owner car. 32,905 is indicated on the odometer which has turned over, all of which is documented with paperwork. I have receipts dating back to the 80’s from P.O.s.
There are approximately 9,149 miles on engine rebuild and transmission overhaul which was done by Original Customs in October 2011.
Click to view attachment Click to view attachment
Engine modifications
2270 cc engine with duel 40 DRLA Dellorto carbs
Tangerine Racing 914 Remote Oil Cooler Take-off Kit (Provides more cooling to cylinders 3 & 4)
Setrab STD 134 oil cooler with two 5” Spal puller fans
MSD 6AL Digital ignition box
Magnecor KV85 8.5 Ignition wire set with High Performance Blaster 2 Coil
Tangerine EVO 914 1 5/8” Street Exhaust
Chassis modifications
911 struts, rotors, Brembo calipers, rebuilt by PMB Performance with Porterfield R4-S pads
New front wheel bearings
Front Elephant Racing polybronze bushings
22mm torsion bars
Tarrett 19mm adjustable front sway bar
Rear Elephant Racing polybronze bushings
New main rear wheel bearings
916 fiberglass front and rear bumpers
Rear adjustable coilovers with 220 lb springs over 50mm Bilstien shocks
PMB Performance rebuilt rear calipers with Porterfield R4-S pads
Drilled rear rotors for 5 lug wheels
Falken 205/50R street tires, treadwear 200, mounted on Fuchs replica wheels
New CV joints
New stainless steel fuel lines
Tangerine Racing Shift Linkage Kit and Shift Rod Bearing
New windshield
Corner balanced
Rust issues
Battery box (hell hole) repaired and painted
Tunnel and pedal area were treated when new stainless steel fuel line were installed.
Jack area on both sides repaired and painted.
Inside of gas tank was cleaned
Cockpit upgrades
Aluminum pedal board
Coco mats
Center Console with the following gauges:
Aircraft SSI-4 sensor to monitor all 4 cylinder head temps
Wideband oxygen sensor to monitor air/fuel mixture
Oil temp gauge
Oil pressure gauge
PM me for more information and/or more photos.
