altitude411
Oct 29 2014, 04:26 PM
What size fitting is on the oil line that connects to this? Is it 33mm? 36mm? TIA
Luke M
Oct 29 2014, 06:11 PM
Do you need to know the wrench size to fit the fitting or what size the fitting id is?
I'll go find my 6 oil return hose and measure it for you.
altitude411
Oct 29 2014, 06:23 PM
sorry for the confusion... I need the wrench size please. I'm 45 miles to a decent parts store and would like to pick up a wrench before heading home. Thanks for your time.
GeorgeRud
Oct 29 2014, 07:23 PM
If you're using original hoses and fittings, 32 and 36 mm open ended wrenches are needed to service the oil lines.
altitude411
Oct 29 2014, 07:27 PM
Thanks for that George, much appreciated.
Cfletch
Oct 29 2014, 08:20 PM
want to buy lol i need of for my conversion
wndsnd
Oct 29 2014, 08:39 PM
What tank is that. Did you test fit it yet? Think it will be an easy install?
John
Cap'n Krusty
Oct 29 2014, 08:52 PM
Looks to me as if it's a factory sportomatic tank.
The Cap'n
altitude411
Oct 29 2014, 09:44 PM
It's just a pic I pulled off the net for a reference. Mine is still in the car.
*I believe it (pic) is a sportomatic tank as per the extra orifices...
gereed75
Oct 29 2014, 10:18 PM
QUOTE(altitude411 @ Oct 29 2014, 11:44 PM)
I picked up a set of open end wrenches at Harbor freight.
http://www.harborfreight.com/15-piece-metr...-set-93668.html They are called "service wrenches". The set has like 21 - 36mm. The quality was adequate to get my oil lines off. set was $49.00 not on sale. They are relatively thin and fit into places they need to to break the lines. You can also easily get a pipe on the ends for LEVERAGE!!
wndsnd
Oct 30 2014, 07:46 PM
Looks expensive.
John
