partwerks
Oct 29 2014, 07:57 PM
For anyone who would happen to have a Boxster shifter, would there be some pictures that could be shared as to the layout/ideas on how the console was set up in the cab?
Mike Bellis
Oct 29 2014, 09:36 PM
You don't need the console. I used the shifter and made a console with a wire frame and fiberglass mat.
It has 4 mounting holes so you can bolt it down.
Click to view attachment I made the linkage on the tranny side. Mine was the Audi version and did not come with the Boxster setup.
Click to view attachmentFinished cover. I cut the Boxster shifter handle down and added a Mustang shifter handle. This allows a screw on knob. The stock Boxster knob sucks.
partwerks
Oct 29 2014, 09:43 PM
Thanks Mike.
I can't tell in the 3rd picture, but is there room for the 3rd seat cushion in behind the console, once it is ultimately put in place?
Mike Bellis
Oct 29 2014, 09:58 PM
You could build it that way. The cables are in the way. Mine dive into the tunnel before the access panel. I could slide the entire thing forward but i fit best where it is.
You could build a better fitting console than trying to fit the Boxster unit.
partwerks
Oct 29 2014, 10:13 PM
I forgot about those cables going to be in the road.
How's come the cables were not routed through the access hole instead?
Mike Bellis
Oct 29 2014, 10:20 PM
QUOTE(partwerks @ Oct 29 2014, 09:13 PM)
Too sharp of a bend to get out the hole in the firewall.
barrym
if you're looking for a shifter for a cable shift conversion - check out the lotus elise / exige shifter
http://www.autobahnpower.com/images/Blog/L...fter1%20abp.jpgthe '06 onwards is the on pictured above - the '05 and below is the same function, just a little more flex in the cage.
partwerks
Oct 30 2014, 07:22 AM
I have the shifter, and cables, just looking for ideas on how to make some sort of housing for the shifter, if I don't use the original console that it would have come with, to make it look decent.
76-914
Oct 30 2014, 08:06 AM
You can run the cables thru the rear access. You can even modify the access cover so that it can be used as well.
Click to view attachmentClick to view attachment
Mike Bellis
Oct 30 2014, 02:10 PM
Those are not Boxster cables...
mr2by4
Oct 30 2014, 02:43 PM
Toyota MR2 also uses cable shift and can be had for a bit less $$ than either of those. I would imagine that, in its 3rd generation, its operation is similar to that of the Lotus (since they shift the same gear box).
Mike Bellis
Oct 30 2014, 03:26 PM
Partworks has a Boxster tranny, Boxster shifter and Boxster cables.
I believe he is wanting info on finish mounting and console aesthetics.
I don't think this is a debate on which shifter to use. What he has is plug and play.
Chris914n6
Oct 30 2014, 05:04 PM
QUOTE(partwerks @ Oct 30 2014, 06:22 AM)
There is some good stuff on youtube. 1/4" fiberboard, sintra, or fiberglass is the most common.
El Vikingo Tropical
Oct 30 2014, 05:45 PM
I use the Boxster shifter on a Audi trans and it's work well.
