Roy,
Too bad you are not closer than 2 hours. I could pack my sawsall and have that 75 in pieces in short order. Welding, well that's something else. You are on your own there.
Honestly, if you need assistance I don't mind the drive. Sometimes you just need 4 hands. I'm retired so available most of the time. I do need copious amounts of coffee though.
As I see it you have 2 projects: keeping the DD on the road and the 75 rustoration. Both are likely to keep your mind working and awake at night.
I'm slowing down on my to do list. Not many items left and when they are all done, then what? I know, there will always be projects that surface.
Good luck/
Bill
Hey Bill! May have to take you up on that if you're up for a drive to NoVa. I have plenty of coffee. Yeah, I have my hands full here but I would love an extra set of more mechanically-inclined eyes and hands. Thanks for all the help you've given me already.
With all the metal you'll be replacing you really need to do a lot more bracing than the simple console jig. Something like what I made for Marks car would be a good start. I was looking at his just yesterday in preparation for making the cuts ( for reals ) and think I'm also going to tack a couple braces to the rotted inner long/wheelhouse while I am repairing the outside, just as added insurance since the inside of his is so bad. You can NEVER have too much bracing, but you can definitely have to little
Hmmm...ok. This is going to require some more thought then. I'm may have some follow up questions, but the first thing is: I assume I need to both brace the frame AND locate the suspension consoles later, correct? Does this setup do this? I see where it appears to connected to the ear, but not the outer console.
Thanks, Mark and Scotty.
I made that jig to connect to the trans mounts, both suspension ears, and then a couple tack welds on the floor pan. That way the locations for the suspension mount are repeatable. The plates rest firmly on the inside of the consoles, and there is a nut welded to the back side of the plate. Bolt goes through the console bolt holes and tightens down
