QUOTE(tomeric914 @ Nov 23 2014, 08:05 PM)
QUOTE(Mark Henry @ Nov 23 2014, 09:30 PM)
True if you don't have covers, but why would you go looking when you already have turbo covers?
It's an easy mod, the trimming cost nothing, and the milling is relatively cheap.
We don't know what he has access to. Maybe he has SC valve covers. Maybe machining isn't cheap or easy for him.
Also, for those who find this thread, they'll have another option other than the false pretense that turbo valve covers are necessary.
I have the turbo covers on my 3.2. After starting this thread and seeing the responses and pictures, I think that the easiest thing for me to do is to modify my turbo covers. I thought about just removing material locally using a Dremel tool and files. Now, I am beginning to think that the easiest thing to do is to take the covers down to my 6 inch belt sander and sand all of the ribs down to the proper height. I guess my question is that removing all that material removes heat transfer surface. So, I can then expect the covers to run hotter, right? And, with more heat, can I expect to see cover warpage and oil leaks? The ribs in the turbo covers provide stiffening; so, machining them down to a thinner profile will remove some of that stiffness.
Those are my thoughts and concerns. What has been the experience of those that have run the modified turbo covers?
