neo914-6
Feb 1 2005, 12:46 AM
Aside from big fuel thirsty trucks, which will be legal and safe...6/8 cyl. SUV, truck, El Camino, station wagon???
I found trailer rentals require 3/4 ton or larger.
MattR
Feb 1 2005, 12:55 AM
fiid
Feb 1 2005, 12:59 AM
Our Legacy GT wagon has an official towing capacity of 2500lbs. My stepfather has pulled WAY more than that behind his old 1.8 wagon (much to the detriment of everything - including a couple of fences - but thats another story) - so I feel pretty confident with the new vehicles. Don't know how much it weighs though if you need to persuade a rental co.
scruz914
Feb 1 2005, 01:04 AM
I used to tow a 22' Catalina sail boat with a GMC Safari (Chevy Astro). Around 3500 lbs. Six cylinder with a heavy duty radiator and transmission cooler. Several trips from Santa Cruz to Tahoe with out a problem. Not the fastest up hill at altitude but not unbearable. I loaned the van to a friend who towed a heavier speed boat up to Shasta with a car load of people. When not towing the van drives like a car, seats 8 plus room in the back.
-Jeff
jandro62
Feb 1 2005, 01:17 AM
you could get a caprice classic, v8 with the towing package - that thing will haul quite a bit as long as you have the steel wheels and not the aluminum ones.
I towed my 914 with an Isuzu rodeo. wasn't that unpleasant for 180 miles. I think the rodeo is pretty fugly though.
neo914-6
Feb 1 2005, 02:28 AM
MattR,
I meant in ONE piece!
Will it have a proper burial?
redshift
Feb 1 2005, 02:37 AM
I think a Mini Cooper S.
M
SpecialK
Feb 1 2005, 05:08 AM
QUOTE (Neo914 @ Feb 1 2005, 12:28 AM) |
MattR,
Will it have a proper burial? |
CRAP!!
Another load of 914 bits I could've used!
Stop the maddness CA guys, the midwest needs your leftovers!
Back to the topic:
I'd trust my (wife's) Jeep Cherokee to tow just about anything that weighed less than it.
GaroldShaffer
Feb 1 2005, 05:45 AM
I find my V6 Dakota Quab Cab does just fine.
ChrisFoley
Feb 1 2005, 06:04 AM
I wouldn't want to use anything smaller than my 6 cyl. Dakota, but it works pretty good. I do have to downshift to 4th going up the big hills though.
SteveSr
Feb 1 2005, 06:17 AM
QUOTE (itsa914 @ Feb 1 2005, 03:45 AM) |
I find my V6 Dakota Quab Cab does just fine. |
As long as your front wheels don't fall off that Dakota Garold
Nice trailer, BTW
SteveSr
skline
Feb 1 2005, 06:19 AM
I have towed many a 914 behind an S-10 truck. Of course they only made them to 2003, now they have the canyon and colorado pckups which are powered by an Isuzu inline 5 cylinder. I wont buy one.
xsboost90
Feb 1 2005, 06:43 AM
eventually my 03 3.0 ranger will be the trailer rig, but ill install a trans cooler when i do it.
machina
Feb 1 2005, 07:01 AM
I would look for wheelbase and gross weight of the tow vehicle. There are lots of trucks (or cars) that can tow a 914. It's just that when you have to swerve or make some kind of quick maneuver, your going to be limited if your tow vehicle doesn't weigh much more than your tow rig. (trailer and car)
Also, I have found that whenever I tow, my truck ends up packed to the gills with stuff I need once I get there. So that doesn't help things either.
ArtechnikA
Feb 1 2005, 07:37 AM
QUOTE (Neo914 @ Feb 1 2005, 01:46 AM) |
I found trailer rentals require 3/4 ton or larger. |
i believe your question contains the answer...
if you are renting, the smallest vehicle is whatever the rental company says it is.
if it's your trailer - well - "trailer" covers quite a spectrum. is it a new, lightweight aluminum commercial trailer or a big, old, home-built iron I-beam thing. what kind of BRAKES does the trailer have? if it's for track events, will you be adding a set or two of spare wheels, 500 lbs of tools & parts, 50 gallons of race gas, a barbecue, and a 20x30 EZ-Up ?
are there mountains where you need to tow? are you at altitude ?
every time this question comes up on the Racing list, the answer is: get the biggest Diesel truck you can possibly afford - your safety and peace of mind will thank you. (it is NO FUN getting scared more by the tow home than your time on the track...)
that said - yes, i'm planning on using our (older) Subie Legacy Outback to FLAT-TOW the 911 to any track events we do next year. i will definitely add a (second) transmission cooler. i pulled a trailer with a 356 around the block once and it went okay but it was not something i'd care to do at length.
scotty b
Feb 1 2005, 07:50 AM
Jeep Grand Wagoneer. Tow in STYLE!!
ConeDodger
Feb 1 2005, 08:36 AM
My V6 Supercharged 4Runner hardly notices my boat until it is time to brake quickly. Trailer brakes might help that some.
groot
Feb 1 2005, 09:24 AM
If you bought the tow vehicle, check the manufacturers ratings.... if you lease it, who cares?
Anyway, it really depends on your trailer. I have towed with a fwd, V6 Escape (rated for 3500#). It wasn't horrible, but living with it the rest of the year is much better than (IMHO) an Explorer.
I built a trailer so it's lighter and I can get away with a smaller tow vehicle. So, my entire rig (enclosed trailer, race car, tires, etc) is less than 3000#.
Mueller
Feb 1 2005, 10:09 AM
Felix,
Have you seen Haydens trailer?
Comprised of bonded aluminum that he designed and built himself (I'm sure Tracy helped
If you designed and built it just right, it could be stowed away easily when not in use.
bondo
Feb 1 2005, 11:03 AM
Uhaul rented this trailer to me, but it was only a half ton. Perhaps they shouldn't have
The trailer itself weight 2000 lbs. It probably didn't help that I put 2 engines, 3 transmissions, and a bunch of parts in the back of the pickup
I have since replaced the truck with a 3/4 ton full size van.
andys
Feb 1 2005, 11:07 AM
QUOTE (ArtechnikA @ Feb 1 2005, 05:37 AM) |
QUOTE (Neo914 @ Feb 1 2005, 01:46 AM) | I found trailer rentals require 3/4 ton or larger. |
Ditto. Anything less than 3/4 ton is pretty much useless if you want to rent (just about anything). It's one reason I kept my fully size van conversion all these years........heavy, long wheelbase, tows great (except for power); very stable. Not refused by any rental yard. Unless you buy your own trailer, you're at the mercy of the yards' and their policies.
If you buy your own/borrow a trailer, I would suggest the heaviest, longest wheelbase (important for stability), and most powerful you can tolerate/afford. Definately avoid short wheelbase, high CG vehicles. They're a disater waiting to happen. Oh, and surge brakes as a minimum.
You might look into a tow dolly. I don't believe the rental yards have any restrictions when renting them(?).
Andy
Carlitos Way
Feb 1 2005, 11:18 AM
QUOTE (andys @ Feb 1 2005, 09:07 AM) |
Andy |
I'd be very leary about a tow dolly with a car as low as a 914... especially if you have to slam on the brakes... or is that the "deluxe braking option"?
Eric_Shea
Feb 1 2005, 11:31 AM
My ML320 (3.2 V6) did a great job over the Sierra/Nevada range. Pretty much 70-something on the cruise through KA. Once I hit Reno I set the cruise at 80 and cruised home.
Problems? Nada. Never even knew it was back there.
Series9
Feb 1 2005, 11:39 AM
I don't recommend an Explorer.
My friend was gracious enough to pull me to Ft. Worth and back for the dip, but with a 2000# trailer carrying a 450# car it was a little scary.
Joe Ricard
Feb 1 2005, 11:46 AM
U-haul won't even talk to you if you have a Ford Explorer.
Yet they said a 93 Ranger would be just fine.
ranger has smaller brakes lighter drive line and Less vehicle weight.
Jenny
Feb 1 2005, 11:49 AM
QUOTE (Rotten Robby @ Feb 1 2005, 06:36 AM) |
My V6 Supercharged 4Runner hardly notices my boat until it is time to brake quickly. Trailer brakes might help that some. |
Sorry to hijack, I'm seriously considering selling my Chevy Silverado for something more economical and fuel efficient, like a 4Runner. I've heard the V6's have a head gasket problem. Yea or nay?
Jen
TimT
Feb 1 2005, 11:51 AM
QUOTE |
I had a mid 90's 4runner, with V6, the head gasket was replaced under warranty
Jenny
Feb 1 2005, 12:01 PM
I'm looking for one around early to mid 90's. My boyfriend swears by the 22RE. I've heard several claims that the V6's blow head gaskets around 60Kmiles, and will need replacing every additional 60. Needless to say, there would be no warranty on a craigslist purchase.
I spoke to a toyota mech, and he says it got something to do with the coolant's PH eventually matching the gasket's PH, and thusly ruining it. Or something to that effect.
Jen
andys
Feb 1 2005, 12:04 PM
QUOTE (914RS @ Feb 1 2005, 09:39 AM) |
My friend was gracious enough to pull me to Ft. Worth and back for the dip, but with a 2000# trailer carrying a 450# car it was a little scary. |
No surprise. That looks like the Exploere XLS. Short wheelbase model sure to have poor stability (short, high, & narrow). I own a standard wheelbase Explorer with tow package. Fine for towing smaller stuff, though has plenty of power to pull a heavier load (I think that fools some people). Narrow track, and high CG doesn't make for a good tow vehicle. Oh, the brakes are horrible on the Explorer.....certainly don't inspire any confidence in sudden situations, even without a trailer.
I tow-dollied my 914 a relatively short distance. Yeah, the low ground clearance concerned me; more so with high-centering it onto the tow dolly, than anything else. Of course backing up with a tow dolly is nearly impossible; a huge limitation IMO.
Andy
type11969
Feb 1 2005, 12:30 PM
flat towed my 914 with my chrysler about 200 miles. No problems and at times I wondered what the hell the moron was thinking that was tailing me so close. Then I realized I was an idiot.
neo914-6
Feb 1 2005, 02:14 PM
QUOTE |
Neo,
Do you need some metal? I made an offer on that car, and might have some to share.
-Rusty
I recently bought a parts car and will need to get rid of what's left in a few weeks. It's contributing it's body parts to alot of 914s!
Oled
Feb 1 2005, 03:51 PM
You could probably get a good deal on a Jeep Cherokee Sport. All of them with the inline 4.0 six and automatic transmission (either 2wd or 4wd) with tow package are rated at 5,000 pounds.
TimT
Feb 1 2005, 04:33 PM
QUOTE |
I've heard several claims that the V6's blow head gaskets around 60Kmiles |
The head gasket in my truck let go at around 80K I was told by Toyota that the new head gaskets were improved compared to the old ones.. There was a TSB about the V6 head gaskets, anyway the Toyota powertrain warranty is 100K miles so yyou should be covered unless the truck has over 100K, I dont know if there is a time limit for the head gasket replacement.
I loved my 4 runner, It just didnt have the balls to trailer. When I started doing alot of traileringh/racing I had to upgrade to something with serious power (Ford F250 diesel)
Joe Bob
Feb 1 2005, 04:41 PM
My Dakota has towed Manfred on a trailer with out a hiccup....full tow package, smog legal Supercharger and a 360 V8....The trailer now belongs to SKLINE and the truck is for sale.....hint hint.....
I also have a four wheel steering Yukon with the 6.0 big block....don't even feel a trailer behind it....
d914
Feb 1 2005, 05:38 PM
this is a little over kill but the new tacoma and or a used Tundra would work great. I used to have a tundra, great truck.
Gint
Feb 1 2005, 08:52 PM
Smallest tow rig I ever used was my Jeep Cherokee (with 4.5" lift at the time). Hauled a 914 on a car dolly from L.A. to Denver with no issues at all. But it was January so the weather was cool. And I didn't cross the Divide on I-70, so the major mountain crossing was the Wasatch range on I80. Only 9000' or so there instead of the 11.5k' over I-70.
URY914
Feb 1 2005, 08:54 PM
See if you can find one of these. Maybe on German Ebay...
URY914
Feb 1 2005, 08:55 PM
Or maybe the Brumos rig...
ajracer
Feb 1 2005, 09:09 PM
Just my two cents worth !
Last JUNE 2004 I used a 2002 Pontiac Montana mini-van to bring back from
Florida my newly acquired 1974 Teener. A total distance of 1700 miles to
Toronto from Orlando, with a rented "Tow Dolly" from Uhaul for the sum of
$ 275.00 Driving with a loaded vehicle and the 914 was no problem as long
as you are attentive and don't need to do any panic braking. Lets put it this
way taveling North of the I75 a few drivers can testify that they were passed
by a Porsche going backward at 70 mph (on the trailer of course). Anyway it
worked out fine since we removed the front brake calipers to prevent any
possbile problems in towing long distance. Looking back now it may not be
the normal way to transport a vehicle but it worked fine for me. All the best
Allan
dan10101
Feb 1 2005, 09:30 PM
Ok, I'll take a chance...
I'm thinking of getting an El Camino. I just hate trucks. What can I say. That's just me. So I've been wanting a muscle car and need someting to tow with. So I'm looking at a 66-72 El Camino. I'll have to do some modifications to make me feel better about towing with it, but so far I've heard good feedback.
Bigger brakes, probably an air bag system, level III trailer hitch, Better engine cooling and trannie cooler. I figure I'll have to tow at least 4,000 pounds. Depending on the type of trailer.
Flame suit on..
My inspriation is a pair on ebay. Both 9 sec quarter milers.
curtis
Feb 1 2005, 09:36 PM
QUOTE (Jenny @ Feb 1 2005, 09:49 AM) |
QUOTE (Rotten Robby @ Feb 1 2005, 06:36 AM) | My V6 Supercharged 4Runner hardly notices my boat until it is time to brake quickly. Trailer brakes might help that some. |
Jen |
I have a 02 4-RUNNER with 29,000 on it did the toyota tech mention anything about the later 4-RUNNERS?
Otmar
Feb 1 2005, 10:04 PM
QUOTE (dan10101 @ Feb 1 2005, 08:30 PM) |
I'm thinking of getting an El Camino. |
You're worried about a ElCamino? Those things are plenty overkill.
Last time I went to Oregon this is how it went. With a 2.0L ABA motor.
I did manage to pass 2 trucks in 1500 miles on the climbs. 12,000 lbs gross on the way home.
Don't try this at home....
dan10101
Feb 1 2005, 10:08 PM
Thanks Othmar, I saw your settup at WCC2004. It's no lightweight. Pretty impressive towing. Maybe I'll weld 2 El Caminos together
Howard
Feb 1 2005, 10:24 PM
Pretty sure this won't fly with this group, but new and cheap, look at Kia Sorrento. 20k list (and they haggle pretty well) gets you everything from curtain airbags to 100k/10yr warranty. 3500# tow cap plus 1200# cargo. 5spd/2wd is the best setup for towing.
Looks enough like a Cayenne so you can get it in black and fake the logos
Sorrento
bd1308
Feb 1 2005, 10:35 PM
try a 914 2.0L .....
Joe Bob
Feb 1 2005, 10:40 PM
QUOTE (dan10101 @ Feb 1 2005, 07:30 PM) |
Flame suit on..
My inspriation is a pair on ebay. Both 9 sec quarter milers. |
Local guy has a nice 72 el camino here for sale. It has an old timer hot rod 350 checvy in it...the builder is pretty famous. Jeonks or something like that...he did a few Bonneville Racers, aluminum heads and a new rtrans...$7500.00, needs ome cosmetic work but no rust. Lemme know if ya wanna number.
Rgreen914
Feb 1 2005, 10:44 PM
Flame suit on..
dan 10101
Many years ago I towed an engine-less, '63 Max Wedge Dodge with a '67 Elco; I used a tandem axle trailer and only towed it about 70 miles. My Elco had 9-passenger wagon rear springs, a 12-bolt rear end with TRW lower control arms and a sway bar; I even had shortened, big-block front springs while running a small-block motor. It was a white-knuckle trip home, as the car and trailer would easily over-react to every steering imput! You might fare better towing a much lighter car but this set-up is anything but ideal. The rig pictured is pretty, but I would bet the car and trailer far outweigh the Elco which would make for treacherous handling! On the other end of the spectrum, I once towed my teener on a U-haul trailer using a dually and experienced nary a problem
Ron
bondo
Feb 1 2005, 10:45 PM
Don't forget to grow a mullet!
dan10101
Feb 1 2005, 11:58 PM
QUOTE (Rgreen914 @ Feb 1 2005, 08:44 PM) |
Many years ago I towed an engine-less, '63 Max Wedge Dodge |
Max Wedge Rocks!
I hear what you're saying. I know things have to be perfect with the setup. Proper tongue weight, balance on the trailer and so on.
Thanks for the input.
Dan,
Mulletless and staying that way, My wife won't let me go even 6 weeks without a hair cut. And I don't have that much to begin with.
