Ghianto66
Dec 17 2014, 12:37 AM
Hello,
Been looking for main bearing for .20 Case and STD Crank, please let me know if anyone have this bearing for spare.
Cheers,
Ghie
pilothyer
Dec 17 2014, 01:51 PM
Were you looking for the center main only or the full set? The center main is the only one in the set that is steel backed. Seems to be in short supply right now if steel backed is a must. If not Standard Crank, .020"/.50mm Case, Standard Thrust Is readily available.
Ghianto66
Dec 18 2014, 03:21 AM
twice buying from web store (i cant tell what they are) they came w/ aluminum bearing (center main). They are Mahle bearing...
i am looking for a set bearing with steel back on the center main.
thank you
pilothyer
Dec 18 2014, 08:33 AM
Ghie............I see what you mean. You would need to look into getting Silverline or Clemax bearings made by Mahle, Here is a link to a place that may be able to get you what you need: Good luck with your search.
STEEL BACK MAIN BEARINGS or
HERE
Ghianto66
Dec 18 2014, 08:45 PM
thank you very much..that is much helpful
Ghie
