I am looking into purchasing a car that has a big bore kit on a 2.0 engine that has been switched from fuel injection to dual webbers. Does anybody know the difference in horsepower, and any concerns with this mod? Thanks in advance
silver2.0
Feb 3 2005, 08:55 PM
depends entirely upon the way the big bore kit was installed, and with what parts? Is it just a 96mm big bore? that's only a 2056.
Bleyseng
Feb 3 2005, 09:21 PM
Unless the motor has a carb cam or a Jake Raby combo you will get a whopping 15mpg vs the 28mpg with the FI. You will also have less torque.
Geoff
Feb 4 2005, 10:07 AM
the bore and carbs won't do you any good unless you also got a more agressive cam to go with the carbs.
if that is the case, you will have more HP than stock and if setup right your gas-milage won't be too bad.
like jake likes to say, it's all in the combo! Andy
PS: i think what i'm trying to say is: we need more details/specs on the motor before anybody can say anything definative ...
Jake Raby
Feb 4 2005, 11:16 AM
All those "Combo" pieces are now available! LOL
