MikeInMunich
Jan 1 2015, 07:48 AM
Can a few of you veterans out there please offer feedback regarding this dynograph?
This is new to me, but I am skeptical here.
Thanks!
Mike in Munich
Jon H.
Jan 1 2015, 08:01 AM
QUOTE(MikeInMunich @ Jan 1 2015, 05:48 AM)
Thanks!
Mike in Munich
I agree for some reason the HP numbers are higher then I thought they would be
Joking aside, that would be disappointing given the money you've invested in the engine. Was this dyno done at the wheels?
Jon h.
JStroud
Jan 1 2015, 08:28 AM
Doesn't look bad, 95hp for a 2.0, wasn't stock only around 80, thats 15 over stock.
Doesn't a 2056 only put out 110-120hp.
EdwardBlume
Jan 1 2015, 08:44 AM
Low HP motor with high torque? Interesting configuration.
I'm guessing from your personal description the chart is from your 1.8 converted to 2.0.
Do a search under dyno and Jake Raby for comparable posted numbers, but its all in how you built your motor.
How does it drive?
Happy New Year!
MikeInMunich
Jan 1 2015, 09:20 AM
The P&Cs add up to about 2.0. Stock cam, mega squirt, MSD electronic ignition, OBX headers. I have not driven it yet but my man on the job says it is indeed "torquey".
I receive another image of the graph with RPM instead of MPH. I've read that the torque and HP lines are supposed to insect at 5220 RPM. This is not the case here. One statement posted by a member read that if they don't the test is bogus or something to that affect.
M.i.M.
MikeInMunich
Jan 1 2015, 09:21 AM
QUOTE(JStroud @ Jan 1 2015, 06:28 AM)
Pretty sure a stock 2.0 puts out about 100.
MikeInMunich
Jan 1 2015, 09:23 AM
Jon h.
I don't know where you got any idea about how much I've invested in this engine Jon. The car had it as is when I bought it. I've only invested in the ignition and headers.
rnellums
Jan 1 2015, 10:07 AM
My understanding is you lose a minimum of 15% off your power going through the transmission. If this is wheel power, Maybe it isn't far off?
BeatNavy
Jan 1 2015, 10:29 AM
QUOTE(MikeInMunich @ Jan 1 2015, 10:20 AM)
That's my understanding (albeit limited). Based on the definitions of HP (work, or power over time) and torque (power), at ~5200 RPM they have to equate, by definition and math. But I don't really understand how dynos work. I've seen several graphs and the HP and torque lines always do seem to intersect at 5200.
MikeInMunich
Jan 1 2015, 01:03 PM
QUOTE(rnellums @ Jan 1 2015, 08:07 AM)
Yes, this is at the wheels, putting output over 90 HP, but we're not seeing the intersection that must be there, mathematically. Also, this motor should be putting out at least 100 HP, or at least we believe it should be. If it's correct we're losing about 10 HP somewhere for some reason.
r_towle
Jan 1 2015, 01:08 PM
Sorry, I don't see RPM,s on this graph.
Stock camshaft, 1.8 heads, it will lose air at the top end and wither away in power fast from what I have seen.
Rich
MikeInMunich
Jan 1 2015, 05:04 PM
QUOTE(r_towle @ Jan 1 2015, 11:08 AM)
Rich
Here is the graph with RPMs. So the heads (and the cam, I knew that) are the weakest link(s). There's a lesson for ya, P&C upgrade to 2.0 ain't doin'
without the top end being upgraded as well. Veterans, please resist to comment "duh" and the like. We all gotta learn the hard way sometimes.
r_towle
Jan 1 2015, 05:09 PM
It's an air pump.
The best money is spent on heads and camshaft.
You may be able to squeeze out a bit more if he changes you over to chomoly push rods, rocker arm shims and sets the valve train geometry properly.
That can all be done without taking the whole motor apart.
It will starve out for air, just as you see it.
That is physics, valves, ports, exhaust.....
Rich
messix
Jan 1 2015, 05:29 PM
loosing every thing starting at 4,200 rpm is really weird.
did you monitor the ignition curve and af/r through out the dyno run?
is this d-jet or l-jet?
some thing is dumping the power way too soon.
I would double check ignition timing and then. and the af/r
this looks more like what a bus motor might look like.
krazykonrad
Jan 1 2015, 06:38 PM
Are you sure you don't have bus heads on this engine?
Konrad
edwin
Jan 1 2015, 07:10 PM
Are you sure you're reading the graph correctly?
I'm reading that you have 76hp at the wheels and 96ft-lbs torque.
Has anyone ever tuned the mega squirt or is it just auto tuned?
messix
Jan 1 2015, 07:42 PM
mega squirt.....
are you dropping in fuel pressure in the higher rpm?
what injectors are you using?
you need to data log on the dyno to figure this out.
I don't see a 1.8 or 1.7 head dumping this much on a 2.0, maybe on a 2.5L+
it's a nice toque curve at first, just getting starved for timing or fuel 4k+rpm
Jon H.
Jan 1 2015, 08:02 PM
QUOTE(MikeInMunich @ Jan 1 2015, 07:23 AM)
Jon h.
Sorry, I assumed you did the the re-build.
Jon H.
CG-914
Jan 1 2015, 08:11 PM
QUOTE(MikeInMunich @ Jan 1 2015, 10:21 AM)
All cars had more hp in other countries especially in Europe...
This is because of less good gas and different emission laws in the USA and especially in CA.
This was mostly done by lower compression in the engines for the US market:
914 2.0 had 7.6:1 compression in the US and 8:1 everywhere else, the Result:
88hp in the USA and 100hp in Germany.
Cornelius
Hamburg and USA
MrLeeS
Jan 1 2015, 10:19 PM
Data logging the run should be standard nowadays. I had a chassis dyno in my shop for 3 years and always ran a wideband just to give the customer something useful from their runs. First thing I'd look at in your case is the throttle and make sure it's opening all of the way. Your graph is a classic example of not enough air flow. And at 2 liters this smaller valves heads shouldn't be pulling you down that much at the top end.
Also, it is obvious the Tourqe and hp are headed for the 5250 intersection, if you can get there.
Good luck.
MikeInMunich
Jan 2 2015, 04:23 PM
QUOTE(edwin @ Jan 1 2015, 05:10 PM)
They tuned the Megasquirt while it was on the dyno. They said they love MS and have experience with it.
MikeInMunich
Jan 2 2015, 04:28 PM
QUOTE(MrLeeS @ Jan 1 2015, 08:19 PM)
Good luck.
Thanks for all the feedback and advice, all of you. I will look into the potential issues and post again. I forgot what injectors we have, but they were not Bosch or original.
MikeInMunich
Jan 2 2015, 04:34 PM
QUOTE(krazykonrad @ Jan 1 2015, 04:38 PM)
Konrad
At the moment, not 100%. Inquiring...
MikeInMunich
Jan 2 2015, 04:37 PM
QUOTE(Jon H. @ Jan 1 2015, 06:02 PM)
Jon h.
Jon H.
No problem.
MikeInMunich
Jan 2 2015, 04:47 PM
This car is FINALLY going on a ship in less than 2 weeks, and will be my little pride and joy (I HOPE!!)
beginning this spring over here in Munich. I haven't driven one of these things for over a quarter century (OMG, seems like yesterday
Is losing power at 4500 rpm going to be seriously irritating or do ya reckon I'll just want to shift around there anyway? I guess that is a bit of a dumb question, as it depends on whether yer racing or not, what you're used to and what you expect.
I'm not going to be racing it, just possible occasional auto cross.
I'm not used to anything but my 125 HP turbo diesel family wagon which handles great, for what it is, and is peppy. I like driving it, so if I enjoy taking an Opel Zafira hard into curves, I'm pretty confident this 914 is going to be a blast one way or another.
And as far as expectations go... Can't say if I'll get used to "expecting" to lose power at 4500 RPM, but I guess that's going to be inevitable.
until I get another one that's done right in the first place. I should have had this thing put on the dyno early in the project instead of last minute. If I had I would have upgraded the heads and cam first. Now it's too late for my taste as I've already invested way more into this car than I originally planned to and I think doing the heads over here would just be too expensive and going too far overboard budget-wise.
M.i.M.
Sea Dragon 914
Jan 2 2015, 06:17 PM
Stock for a 73 or 74 2.0 was 95 DIN or 91 SAE.
QUOTE(MikeInMunich @ Jan 1 2015, 07:21 AM)
r_towle
Jan 2 2015, 07:00 PM
QUOTE(MikeInMunich @ Jan 2 2015, 05:47 PM)
M.i.M.
You will love it.
MikeInMunich
Jan 3 2015, 03:09 AM
Thanks Rich, I reckon you're very right. Nonetheless, I've decided these results and this "situation" isn't quite acceptable for my expectations of what this car was supposed to be and that I will now attempt to organize a ready-to-go / plug-and-play top end package, for which I will now make a separate post, today, under WTB.
Please feel free to make suggestions for what it is exactly that I should include and possible sources, as well as what ya reckon the parts should cost!
When finished I will have it back on the Dyno and post the new results.
Thanks!
M.i.M.
JStroud
Jan 3 2015, 08:30 AM
QUOTE(MikeInMunich @ Jan 3 2015, 01:09 AM)
M.i.M.
Not sure it's that simple, to replace the heads you would need to recheck your deck height, redo the valve train geometry, plus I don't think just replacing the heads will give you the results you want, if you have a stock cam, that will limit you, to change the cam is splitting the case....
If it's a 1.8 built to a 2.0, did they change the crank? If not then it's not even a true 2.0.
Not sure who is helping you with your engine building, but I'm surprised there wasn't better communication about what you expected from this motor. If you had a hp rating in mind, they should have been able to come up with a combo to produce that.
I'm just wondering if you need to talk with a more experienced engine builder to get what you want, hate to see you throw more money at it only to be disappointed again.
Would it be an option to just take the car as is, then eventually have the motor built you want, then swap them and sell the first. Keeps the car driving.
Good luck hope it all works out.
Jeff
MikeInMunich
Jan 3 2015, 09:50 AM
Hi Jeff,
Thanks for your input.
I would have been specific but the engine was already done before I bought the car. I do realize that it would be recommendable to change the cam as well as the valves, etc. along with the heads. I may well just accept it as is and if I am not satisfied with its performance I may, as you suggest, eventually have an entire engine sent over here next time I re-import one.
Extra space in the container goes for about $175 a cu. meter.
I'm interested in opinions about HAVING to shift at 4500 or lower. Is this normal? Would it be extremely annoying? Not optimal but acceptable? Opinions?
M.i.M.
ChrisFoley
Jan 3 2015, 10:04 AM
QUOTE(MikeInMunich @ Jan 3 2015, 10:50 AM)
Hi Jeff,
M.i.M.
There will be times when you want at least another 500 rpm.
Without a build sheet for that engine its impossible to prescribe any remedy short of a complete rebuild.
r_towle
Jan 3 2015, 10:26 AM
Call European Motor Werks in California.
He may have all the parts you need.
have him pull the motor out , pull the heads, and post up some pictures and measurements.
Measure the crankshaft throw so you know what you are dealing with when you go buy Pistons.
Bleyseng
Jan 3 2015, 10:41 AM
What cam was used besides it being called a "stock cam"? The Web142? What is the CR? 4500 is where a stock engine starts to fall off powerwise unless you go to better cam and bigger valves with better springs. What intake setup are you running? 1.7 or 2.0L?
The dyno graph isn't too far off a 1911 build at 76 rwhp. That's about 85flywheelhp which is what you expect.
MikeInMunich
Jan 3 2015, 10:57 AM
QUOTE(Racer Chris @ Jan 3 2015, 08:04 AM)
Hi Jeff,
M.i.M.
Thanks for the feedback Chris. No build sheet available at the moment. Will inquire. Have a great weekend!
hydroliftin
Jan 3 2015, 01:13 PM
Am I the only one noticing he is running the OBX header? I have no personal experience with them, but from what I have read they could be the problem.
Jan 3 2015, 01:16 PM
QUOTE(hydroliftin @ Jan 3 2015, 11:13 AM)
I'm sure *if* one manages to make them fit, they probably work fine. However, last i heard, they need cutting and rewelding to fit and seal correctly.
MikeInMunich
Jan 3 2015, 01:28 PM
QUOTE(SirAndy @ Jan 3 2015, 11:16 AM)
Hello Sir Andy,
we die have to modify them and did MAKE them fit. I was not personally involved in this "we", but it is my project, so...
This thread has photos:
http://www.914world.com/bbs2/index.php?sho...31038&st=20
MikeInMunich
Jan 3 2015, 01:31 PM
See reply above...
Other than making them fit, what could be a problem with them?
r_towle
Jan 3 2015, 01:54 PM
QUOTE(Bleyseng @ Jan 3 2015, 11:41 AM)
r_towle
Jan 3 2015, 01:59 PM
Because it's probably a short stroke with the 1.7 or 1.8 heads, you may want to consider buying a built motor from one of our vendors here and just bolt it in place.
A 2056 motor may give you what you need.
The difference between that and your motor is as follows.
Larger stroke crankshaft
Larger Pistons and cylinder ( Pistons will have a different pin height for the larger stroke)
Most likely a different camshaft and lifters
2.0 liter heads.
When you add up all those parts, and the cost to take apart the motor you have now, it may be a better use of your money to pull that motor and sell it, it's probably a decent motor, just not what you want.
One of our vendors here can set you up with a long block in pretty short order and send it to your mechanic to install it.
Rich
MikeInMunich
Jan 4 2015, 03:52 AM
Update:
Thanks for your feedback gentlemen. Sorry for not answering specific questions, as I did not have the info. By the way, though I don't know any of you personally, I think y'all are awesome and I want to say here and now that I LOVE 914 WORLD!
If any of you are ever in Munich, DO get in touch and I'll be happy to let you enjoy my car with me a bit out in the gorgeous Bavarian countryside!
As I'm sure many were thinking while being reluctant to come out and say it, the idea of a quick changeover of the top end and the cam is too hectic and just asking for trouble. Last night I stumbled upon a J.R. comment on the Samba about doing research for SIX MONTHS before making any decisions on a rebuild.
Sounds a bit extreme, but does make one think 6 days just ain't gonna cut it.
So, I've decided to leave it alone...BUT...we will be trying to determine if there is an easy fix to this rapid drop in power after 4500 rpm...
We will check the timing and valve adjustment again, and the throttle, and...what else could be the culprit?
M.i.M.
wndsrfr
Jan 4 2015, 08:37 AM
QUOTE(MikeInMunich @ Jan 4 2015, 01:52 AM)
Update:
M.i.M.
Post up the fuel values table for the MS....you might be running out of fuel at the top end??
JStroud
Jan 4 2015, 08:55 AM
Mike,
I think you made the right decision, trying to basically rebuild the motor in your time frame just has disaster written all over it. Too many things that could go wrong, getting the right parts could take that long....then if you needed machine work....
I think trying to optimize what you have is the right move for now, you would hate for your car to miss the container or be loaded not running.
You may be surprised with what you have, unless you plan on racing it I'm not sure it will affect anything, forget HP ratings, just turn the key and drive it.
They're still the funnest car to drive.....regardless of power.
Expect to have fun and you will.
Jeff
MikeInMunich
Jan 4 2015, 02:38 PM
Great post here by The Master himself...
He says the 1.7 case is the best and the 1.8 heads have advantages over the 2.0 heads as well. Performance should be better with the 2.0 heads, but it comes at a price.
"The 2.0 914 heads are the only real "Porsche" heads found on the Type 4 engine. They feature 3 stud intake manifolds, the largest chambers and their own spark plug location. These are the most rare heads and also the heads that have the weakest combustion chambers, 95% of the time they are cracked and require machine work and a full rebuild. They are the most expensive heads to work with- period. They will make the most power of any stock head, due to the plug location, valve sizes and combustion chambers but the performance comes with a cost."
http://www.914world.com/bbs2/lofiversion/i...hp?t141448.html
MikeInMunich
Jan 16 2015, 01:58 AM
Update: I never did get values for the AFR, but we did discover that the throttle wasn't opening all the way. Apparently the accelerator pedal stop screw in the floorboard was out too far.
New results were somewhat better but not much. Max torque was 106 at around 3500 rpm, HP at the flywheel maxed out at just under 95, allowing for 15% loss in the drive train.
Power drops off by 5 HP between 4500 and 5000 RPM and more steeply after that.
Compared to the original results, max torque went up from 94 to 106 and max HP went from 76 to 81. Supposedly the engine was not fully warm at the time of the test. The results, as you can see, got better with each run. Not sure if the engine was fully warm at the time of the last temp. At optimum temp we might be able to eek out 100 HP.
I was told that in the graph below...Green is in 3rd gear, Red is in 2nd, Blue is in 4th. I was told that the blue line is jagged because it is in 4th gear. Jake Raby chimes in below and suggests that the reason for this is that the plugs are fouled. But they are brand new. Looking into it...
Strange is that the torque and RPM intersect at 4300 and not at 5200 where they should. ?? Dave Darling however comments on the likely reason for this below.
M.i.M.
Dave_Darling
Jan 16 2015, 11:01 AM
95 DIN HP is stock for a 2.0 motor. I forget if that's what you have or not.
The lines do not intersect at 5250 RPM because the torque and power are using different scales. The line showing 30 HP, for instance, is at about 43 lb-ft of torque.
--DD
MikeInMunich
Jan 16 2015, 11:12 AM
QUOTE(Dave_Darling @ Jan 16 2015, 09:01 AM)
--DD
Thanks Dave.
The engine is a 1.8 with stock cam and heads. P&Cs are 96 mm. Not sure if the displacement is 1971 or 2056 as I am not sure of what the stroke of this crank is. Only the P&Cs were changed. The car has headers.
M.i.M.
McMark
Jan 16 2015, 11:36 AM
1.8 crank is66mm stroke
MikeInMunich
Jan 16 2015, 11:44 AM
QUOTE(McMark @ Jan 16 2015, 09:36 AM)
Correction. I forgot, it has a stock 2 liter crank. Is that 71 mm?
Can you tell me what the volume is in total? I seem to be adding it up wrong on the calculator.
MikeInMunich
Jan 16 2015, 11:48 AM
--DD
Dave, the dyno was done in CA. Max HP was 81.5. Is this DIN HP or are you assuming this measurement was done over here in DE. Not finding a quick answer to this question online. Is DIN HP PS...Pferdestaerke...literally, "horse strength". DIN, by the way, stands for Deutsche Industry Norm...or in English...GIN. German Industry Norm.
