brooks944
Jan 3 2015, 09:51 AM
I'm trying to replace my ignition switch on my 75, 1.8L. I've been following the Pelican write up but my car doesn't have the two screws to pull the switch as shown in Pelican figure 10. How do you get this thing out on a '75? Photo of my car attached.
Thanks,
Rick
brooks944
Jan 3 2015, 11:22 AM
I got the tumbler out. Do you have to pull the whole unit off the steering shaft?
JeffBowlsby
Jan 3 2015, 11:26 AM
What are you trying to do? Did you unplug the harness off the back? You have to remove the mechanical part of the switch to replace the electrical part that mounts inside the back of it. Look for the tiny little screw on the side.
brooks944
Jan 3 2015, 11:29 AM
Thanks Jeff. Yes all harnesses are disconnected. Can you get to that screw while it's in the car?
JeffBowlsby
Jan 3 2015, 12:08 PM
Don't think so its tiny, and I am pretty sure its concealed when the lock assembly is in the column. Been awhile.
StratPlayer
Jan 3 2015, 12:10 PM
SLITS
Jan 3 2015, 12:36 PM
brooks944
Jan 3 2015, 01:32 PM
Thanks, these are very helpful. It looks like it's the "C" clip holding it on. Will try removal and let you know how it goes.
Rick
brooks944
Jan 3 2015, 03:02 PM
Thanks Ron with you photos I got it out and replaced the switch. One more question (at least for today....). There was a crush ring connecting to the steering column. It looks to be shot now and is making it hard to get the assembly back on. Is it necessary or can I leave it off?
Rick
SLITS
Jan 3 2015, 03:53 PM
If you are talking about the crush ring that goes around the steering shaft and slides inside the bearing, it is there to take up slop in the steering wheel .... silver(?), serrated, split in the middle. If left out the steering wheel will wobble a bit when pushed up/down / side to side.
If anything else, I need an image to see what you are talking about.
brooks944
Jan 3 2015, 04:04 PM
Yes, that's exactly what it is. It is making it very hard to move the unit up and down the shaft, plus hard to get all the way back to reinstall. Sine I need it, how do I get it back into position?
Rick
SLITS
Jan 3 2015, 05:22 PM
If you have the assembly in position on the steering shaft and secured, you then try to install the sleeve. As I remember, I used a drift to tap it in without destroying it.
Currently, you can get them new and they are a 928 part.
brooks944
Jan 3 2015, 05:28 PM
I'm sure I can get in in and secured, but what is a drift to get it back in? Do you have a pic?
I really appreciate your help!
Rick
PBC914
Jan 3 2015, 06:48 PM
You're close! Remove the c-clip from around the steering shaft. All of the connectors at the back and it will slide off. Yes it's a pain!
SLITS
Jan 3 2015, 06:55 PM
QUOTE(brooks944 @ Jan 3 2015, 03:28 PM)
Rick
Drift = flat headed punch or piece of pipe the correct diameter over the steering shaft or a piece of wood to push it into place. A screwdriver will dig into it.
PBC914
Jan 3 2015, 06:58 PM
You don't need a drift for this job. It's easy remove the c clip from around the steering shaft and the entire piece slides off.
brooks944
Jan 4 2015, 10:53 AM
Thanks guys, got it done. What a Pain. About 4 hours for a $5 part! Since I'm free labor, another 914 adventure that should be easier if I ever try this again. I also installed a new Dino steering wheel as well, which looks great, so this project was like a two for one!
Rick
