QUOTE(steuspeed @ Mar 25 2015, 05:53 PM)
My heater fan was still intermittent after I took it apart. As near as I can tell, the circuit grounds when these two surfaces make contact. I can see a tiny spark when they touch, and relay 55 switches to run the heater fan. Can anyone confirm this is how it is supposed to work? I polished the surfaces with my dremel wire brush attachment. It seemed to help, but it does not take much movement for it not to work. Any comments, suggestions or help appreciated.
You are correct with the contact on the handle. I had such a problem that I ended up running an extra wire to complete the circuit. I just couldn't get the handle itself to make the contact.
