QUOTE(pbanders @ Nov 19 2015, 11:15 AM)
I haven't got much to add, Bleyseng and Bowlsby know more about how to adjust MPS's than I do now! Only thing I'd say is that my LCR data should be used to just get an MPS initially set up, especially with modified engines. The gold standard should be to adjust the MPS while running the car on a dyno with a shop-quality gas analyzer measuring the AFM. Bowlsby and Bleyseng can comment, but my take is to do the main mixture adjustment under part-load at 2 or 3 engine speed settings (e.g. 2000 rpm and 3000 rpm) and set it to 13.7:1, and to do the full-load adjustment to 12:1. I do mine on the road with my less-than-shop-quality AFM and I've gotten good results.
It is wonderful to see a hero post this. Thanks so much for all you put together.
My $0.02 is that when I needed a replacement cam I decided to step up to a modified Webcam and increased the compression ratio. So easy to do while you are at it. I have no comparison data but I believe that made it harder to set the MPS for optimal running. I have to run rich to make it run cool.
I bought an inductance meter on ebay and found that a stock unit ran just as you said it would. My own MPS had lost the original settings during disassembly and I managed to tune it according to your graph, making multiple graphs from different units and after tuning on the car. The initial setting made the car turn over, but I had to tweet it after that with multiple trips around the block in between. I drilled the cap and made my own tools, but they are just what you can buy.
I wish I could log vacuum and my gauges so as to get A/F and CHT along with vacuum and RPM. I keep swerving off the road when I look at the many gauges added on.
Thanks again!
