nine9three
Mar 7 2015, 06:26 PM
I'm going to get some basic alignment at home and need to figure out my front and rear track. I have just converted to 5 lug with carrera struts, standard 911 hubs (no spacers), re-drilled 4 lug to 5 lug rear hubs and 16x6 (36 offset) Fuchs with 205/50/16's. Any other alignment specs for this setup would be greatly appreciated.
messix
Mar 7 2015, 06:40 PM
QUOTE(nine9three @ Mar 7 2015, 04:26 PM)
the exact track width will vary with how much camber and ride height you will have.
it kinda all changes with wear those are set
screenguy914
Mar 7 2015, 07:15 PM
Take your pick. Depends on your equipment, your application and preferences:
https://www.google.com/?gws_rd=ssl#q=914-6+alignment+specs
wndsrfr
Mar 7 2015, 07:37 PM
Hmmmm......not sure you need to know the track to do the alignment...here's what I do:
#1 Ha Ha....car must be off the jackstands...just a little humor...
-Car on flat & level rolled back & forth to settle suspension.
-Set boards or pipes front & rear crosswise on the aforementioned jackstands with top of boards at level of the center of your wheels.
-String fishing line down each side of car placed about 4-6 inches out from the wheels.
-Make sure they're exactly the same distance apart on each of the boards, like 82 inches both front and rear.
-Now jiggle them to get the same distance from the center of the hubs to each line. Front will be different than rear, but as along as fronts are equal and rears are equal, then they are parallel.
-Now measure your toe-in (or out) by measuring the distance from the rim to the line front and back of each wheel rim. For example to get 1/16 inch toe in on each side you might see 4 & 1/2 inches at the back of the rim and 4 & 7/16ths at the front.
-You can convert that 1/16 inch to degrees with geometry...depending on if you have 15 or 16 inch rims or whatever. Isn't it arctan of 1/16 divided by 15...yeah, that's .0042 radians which is 0.24 degrees.
Now, for camber, use a big carpenter's square or a nice piece of plywood that's square to do the same measurement top and bottom with the square set on the flat floor. (Or drop a plumb bob line from a board placed across the fenders--same-o same-o) To get about two degrees of camber on a 15 inch wheel you'll need to see just over 9/16 inches difference top to bottom (top distance more than bottom distance for negative camber). Make sense??
nine9three
Mar 8 2015, 12:16 AM
QUOTE(wndsrfr @ Mar 7 2015, 05:37 PM)
Thanks for the lengthy reply. Yes, this makes sense and I'll give it a try.
nine9three
Mar 10 2015, 01:10 PM
Can anyone confirm what a complete turn of a Turbo tie rod nets you in terms of (inches) or degrees? I found in Ray Scrugg's outline that one full turn nets 1/8". Is this correct?
wndsrfr
Mar 10 2015, 07:21 PM
Hmmmmm........grab your caliper and measure the pitch of the threads, or if you don't have a caliper, measure off one inch and count the threads & divide to get the pitch.
Then, multiply the pitch in inches times the ratio of the radius of the wheel to the length of the steering arm ....make sense?
Even so, I'd still measure it off with the strings to confirm the resulting final toe.....
76-914
Mar 10 2015, 09:47 PM
Great info John. Do a write up and include the rear procedure too, pls.
