enf2232
Mar 28 2015, 03:35 PM
Looked at 74 1.8 today. If car was moving, not able to put in first gear. Seller noted that first was not syncomeshed. Is this true or was he covering up a problem?
messix
Mar 28 2015, 03:38 PM
not true
it might need clutch cable adjustment or a first gear sycro and or slider
914Sixer
Mar 29 2015, 05:53 AM
All of the above and shifter bushings.
Dr Evil
Mar 29 2015, 09:00 AM
Only R is not synchromeshed. All forward gears are. If you get 3-5 then 1st is the problem. If you get no gears, then bushings, cable, clutch is on the suspect list.
