Allan
Feb 16 2005, 04:00 PM
Anyone know the most likely source to find a tubing beader that will do 3/8th inch stainless? I've tried the local plumbing places and flaps but no luck. Thanks
TimT
Feb 16 2005, 04:11 PM
3/8 dia?
Smart Racing and Bead form sell them, but I dont think they work on that small dia tubing.
Lowbuck tools also sells it
Aaron Cox
Feb 16 2005, 04:26 PM
allan...what are you up to????
Allan
Feb 16 2005, 04:30 PM
Fuel lines my friend.................
TimT
Feb 16 2005, 04:31 PM
that bead form machine does down to 5/16... but it costs about $275
Aaron Cox
Feb 16 2005, 04:34 PM
QUOTE (Headrage @ Feb 16 2005, 03:30 PM) |
Fuel lines my friend................. |
oh...very good my friend.....very good......
Allan
Feb 16 2005, 04:36 PM
I found
This one but it only does aluminum. When I called on the the guy told me that most racers run aluminum lines. Will they work on our cars or is there an issue with aluminum?
airsix
Feb 17 2005, 12:36 AM
Allan,
you could just get a flaring tool at your FLAPS and put brass fittings on the ends of your tubing. This is what I do. The flare tool was only $6 or $7. Then I use brass fittings with hose-barb ends or whatever is needed.
-Ben M.
nsyr
Feb 17 2005, 08:32 AM
Allan
Feb 17 2005, 08:59 AM
Looking for a Tubing "Beader".
GWN7
Feb 17 2005, 09:31 AM
Holley
BeaderEarl's EZ-BEADER produces a properly positioned and perfectly radiused bead on aluminum tubing with wall thicknesses from .035" to .065". This is one tool that no serious racing mechanic can afford to be without.
Application Chart
P/N TUBE O.D.
008ERL 3/8"
009ERL 1/2"
010ERL 5/8"
011ERL 3/4"
012ERL 1°
013ERL 1-1/4"
014ERL 1-1/2"
015ERL 1-3/4"
016ERL 2"
018ERL Set of all nine
says for aluminum tubing
Allan
Feb 17 2005, 10:53 AM
Yep, I saw that. Problem solved. Going with aluminum. Thanks!!!
