Tubing Beader, Where to get? |
Allan |
Feb 16 2005, 04:00 PM
Anyone know the most likely source to find a tubing beader that will do 3/8th inch stainless? I've tried the local plumbing places and flaps but no luck. Thanks
TimT |
Feb 16 2005, 04:11 PM
3/8 dia?
Smart Racing and Bead form sell them, but I dont think they work on that small dia tubing. Lowbuck tools also sells it Attached image(s) |
Aaron Cox |
Feb 16 2005, 04:26 PM
allan...what are you up to????
Allan |
Feb 16 2005, 04:30 PM
Fuel lines my friend.................
TimT |
Feb 16 2005, 04:31 PM
that bead form machine does down to 5/16... but it costs about $275
Aaron Cox |
Feb 16 2005, 04:34 PM
oh...very good my friend.....very good...... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Allan |
Feb 16 2005, 04:36 PM
I found This one but it only does aluminum. When I called on the the guy told me that most racers run aluminum lines. Will they work on our cars or is there an issue with aluminum?
airsix |
Feb 17 2005, 12:36 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Allan,
you could just get a flaring tool at your FLAPS and put brass fittings on the ends of your tubing. This is what I do. The flare tool was only $6 or $7. Then I use brass fittings with hose-barb ends or whatever is needed. -Ben M. |
nsyr |
Feb 17 2005, 08:32 AM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
Allan |
Feb 17 2005, 08:59 AM
Looking for a Tubing "Beader". |
GWN7 |
Feb 17 2005, 09:31 AM
Holley Beader
Earl's EZ-BEADER produces a properly positioned and perfectly radiused bead on aluminum tubing with wall thicknesses from .035" to .065". This is one tool that no serious racing mechanic can afford to be without. Application Chart P/N TUBE O.D. 008ERL 3/8" 009ERL 1/2" 010ERL 5/8" 011ERL 3/4" 012ERL 1° 013ERL 1-1/4" 014ERL 1-1/2" 015ERL 1-3/4" 016ERL 2" 018ERL Set of all nine says for aluminum tubing |
Allan |
Feb 17 2005, 10:53 AM
Yep, I saw that. Problem solved. Going with aluminum. Thanks!!!
Lo-Fi Version | Time is now: 17th May 2024 - 05:43 PM |
