thieuster
May 5 2015, 01:52 PM
Guys, my car's back window looks to be loose from the rubber that sits between the engine cover and the window. Before I try to correct that, I would like to see some pics of a properly installed window, especially from an angle where I can see it positioned like it should be - between the head rests of the seats.
Next to that: can you point me towards a proper 'how to remove and reinstall the rear window'? I've found a thread from a few years back that mentions the use of some sort of foam.
All advice is welcome!
Menno
Shadowfax
May 5 2015, 03:04 PM
Here's the write up I used this past weekend. Has some good pics. Was able to find the butyl tape 4196 on the shelf at Napa.
http://www.914world.com/specs/EricSheaRearWindow.php
Ian Stott
May 5 2015, 03:48 PM
Just finished doing it about 3 hours ago, followed Eric Shea directions and had no problems. Got a roll of the recommended butyl from a glass shop, had a very good helper, well actually I was the helper! Went for a drive and my rattle is gone, it was the window.
Ian Stott
Moncton
Canada
colingreene
May 5 2015, 09:05 PM
I actually think that tape is a bit on the thick side...
PanelBilly
May 5 2015, 09:11 PM
Not OEM, but not much on my car is... I use black Gorilla tape. Stuff goes on like duct tape and sticks like crazy
thieuster
May 6 2015, 02:15 AM
Thanks guys! Exactly what I need!
Menno
Ian Stott
May 6 2015, 02:09 PM
QUOTE(thieuster @ May 6 2015, 05:15 AM)
Menno
Would have posted pics if I could. kinda computer challenged, glad you made out ok.
Ian
