skline
Feb 21 2005, 02:25 AM
I will start, I have to change out the front and rear shocks on the 74, install front and rear sway bars, tires, some body work and primer, front steering fixes like tie rods and ball joints, check the brakes, they feel weak and change out the heat exchangers and install the 2 liter ones with muffler, install front fiberglass bumper, euro lenses all the way around and replace a few hoses. The Chalon, I am still waiting for the rear roller control arm bushings, I need to swap out one front strut, bleed the brakes again, alignment on front and rear, finish installing the carpet and speakers, block and primer the body, secure the battery, trunk release, rear Porsche reflector, Engman pedals, and weather striping. Of course I need to go back through and double check everything and then dial the engine in so it runs perfect. Or as perfect as I can get. Its going to be close. Hopefully some of the boys will come help me out with some of it.
Dr Evil
Feb 21 2005, 02:48 AM
Pay, register...oh ya, and make my car run
Brando
Feb 21 2005, 04:18 AM
Door panels, interior, carpet, firewall carpeting, 'finish' my seat mounts, new engine, hook remote oil cooler back up, replace seals (orrh orrh!), remove seatbelt warning/start disabling system, install new speedo cable, finish gauges, new windshield new chrome trim and attachment tabs, bodywork, new battery tray, treat my 'minor' hell hole, por-15 the firewall and engine bay, paintjob and headlights.
xsboost90
Feb 21 2005, 06:56 AM
next 60 days..im thinking 30days and run brake lines, get mc and install, bleed, etc..., install motor, get to run, buy optic ignition, sand/strip, bodywork, primer, block,primer, block, wetsand, paint, buff, interior, seat brakets, stereo, paint wheels, clean, clean clean, tailights, rubber, headlights, rubber, markers, have dash pieces made, install, wax, wax, clean clean,...rest.
rick 918-S
Feb 21 2005, 07:56 AM
I need to reinstall my engine mount bar, (pulled it out to copy it for Larry) repair some body damage, and do some detail work like cleaning and painting etc. It's not a show car but it's just as much fun.
Mueller
Feb 21 2005, 09:14 AM
I have to do:
new front a-arm bearings (needle bearings of course), powdercoat front arms,
new vented rotors,
billet front hubs
possible new master cylinder due to my new calipers
make 1.25" thick wheel spacer for front to slide over my 90mm wheel studs
make billet adapter plate for RX-7 calipers
install new headlights
install side marker light (I need a drivers one)
paint drivers side fender
paint top of windshield frame
put new seat coverings on the seats
install stereo
install speakers
install amp
install carpet
replace clutch and throttle cable
powdercoat rear trailing arms
install bearings for suspension in the rear
install rear wheel bearings
new rear rotors
new rear calipers
install rear window
replace all of the window/targa top seals
build new 2.2 nickies equipped engine
finish the intake system
tune the new engine
install C/F deck lids
Andyrew
Feb 21 2005, 11:07 AM
Install flares
put Edelbrock intake and holley carb on
tune for 250hp (detune I should say..)
Install CV.
Get tires on my 17's
get spacers
carpet interior
mount second race seat
fix leak in radiator system (one of my soders has a pinhole leak)
Get 916 rear bumper or cut valance out for time being.
Finish front flares
Finish front hoood
Install new bearings in rear hubs
Paint/powdercoat 17's
Get 180's on rear
get adjustable spring pearches
Put car in primer
get new front lenses (euro)
Rewire car
new bushings on front and rear.
Quit jobs so I can have time to do this
Ya, thats what I'd really like to do...
Andrew
Series9
Feb 21 2005, 12:15 PM
This list is much shorter than it was on 1 Feb. Here's what's left:
WCC05 Checklist 1 Feb 2005
Items in bold complete prior to 1 Mar to put the car on the road.
Engine/tranny:
Install clutch helper spring on tranny
Body:
Rear window (Lexan)
Compound paint
Touch up as necessary
Install bumpers
Install rockers
Install valences
Seal for front deck
Fab rear trunk panel
Repaint faults under header
Repaint faults in rear trunk
Buy/install fog lights
Grommets near oil cooler
Interior:
Firewall covering
Install trim panels: windshield, upper hoop, roll bar horiz, roll bar verts
Paint gauge surround
Passenger seat
Passenger seat belts
Angle bar coverings
Trim windshield adhesive
Suspension:
Plate upper suspension hardware
Retighten everything
Alignment/ride height
Install sway bar drop links in the rear
Demick
Feb 21 2005, 02:49 PM
I only have one thing on my list:
1. Make sure 914 will make it there and back!
Demick
xitspd
Feb 21 2005, 04:21 PM
Joe,
Where did you get the Lexan rear window? Your list is getting much shorter, keep up the good work.....
Dan
TonyAKAVW
Feb 21 2005, 04:50 PM
Lets see. Since December I have gotten a ton of things done on the car but I still have a few things to do. So far I have:
+Stripped down the floorpans to metal, POR-15'd them and fixed a couple rust holes by welding in new metal.
+Adjusted the window cranks and door handles to operate more smoothly
+installed 4 new rubber seals (engine lid, front trunk, rear-edge of window seals
+Finished the carpeting
+replaced the brake master cylinder
+installed new flexible rubber brake lines
+new seals and pads on front brakes
+installed sway bar in front
+replaced rear springs with 140 lb springs
+replaced all four shocks
+replaced fuel lines from gas tank
+Fixed the "on" portion of the ignition switch
+registered for WCC
A few things left to do including:
-redo the valve cover seals
-pushrod tube seals
-fix the front trunk (some big holes, some rust)
-replace the targa top side seals and adjust to keep water out
-get a helmet
Thats about it. I figure thats two good weekends of work. One for the front trunk and one for the rest. Once this damn rain stops I can get back to work on it.
-Tony
JoeSharp
Feb 21 2005, 06:04 PM
Cover the check.
Joe
drew365
Feb 21 2005, 08:23 PM
I just have to:
Hope the guy that's rebuilding my engine can get it finished in time.
Hope I can afford to pay him so I can get my car back.
I was hoping it might be painted by then but it's not looking good so you guys will just have to contain the snickers.
VegasRacer
Feb 24 2005, 06:34 AM
I would be in much better shape if I could stick to the items on my list.
Instead of working on the interior like I should be, I decided today that replacing all 4 calipers would be a good idea.
That is something that was on my 'one day in the future' list. I came across a nice set of SC brakes, so I figured "why not now?".
