I also finished the radiator shroud to keep high pressure from forming under the front trunk while at speed. The air is forced into the radiator and then pushed out the bottom where the spare tire well used to be. As for the engine bay, I wanted to make it look cleaner so I thought of putting a "shroud" like the engine tin on the original engines. I was able to use the grooves already in the car to secure the 1/16" aluminum sheet used. It also acts as a heat shield from the headers, located directly under the intake manifold.
And I had this windshield banner made for the long trip up to NC for Okteenerfest since I dont have sun visors
