These are the guys located across the sound in Monroe, WA. I have a 1975 2.0 914 with 76K (don't know if it's original or not)
PR007834
REINZ Complete Engine
Gasket Set
73-76 2.0 52.81
BH021911
BOSCH Air Filter
914/4 1.8 & 2.0 6.02
VW022612
CONTINENTAL V Belt
914/4 Air Pump 4.71
VA022642
CONTINENTAL V Belt
914/4 Alternator 5.19
VA006426
KS Camshaft Bearing Set
914/4
13.24
PR007828
TRW Intake Valve
914/4 2.0 Ltr.
39.51
PR007829
TRW Exhaust Valve
914/4 2.0 Ltr. 61.22
PR006339
TECHNOVANCE Intake Valve Guide
914/4 .476" OD 1975 2.0 Ltr. Only 2.33
PR007838
GENUINE Engine Mount
914/4 73-76 16.18
VA053702
WHITE BOX Fuel Filter
914/4 75-76 3.76
VA006385 MAHLE
Oil Filter
914/4 4.64
VA057084
TOPLINE Oil Pump
914/4 62.77
VA010078
SABO Oil Pump Gasket
914/4 0.05
VA006384
MILLER Oil Strainer Gasket
914/4 0.85
PR007836 GOETZE
Piston Ring Set - Engine
914/4 2.0 Ltr.
94 - 1.5 x 1.75 x 4mm 65.94
VA007824
KS Rod Bearing Set
914/4 2.0 Ltr. Std. 28.32
VA006418
KS Main Bearing Set
914/4 Std.
46.99
grand total. 414.47
is there anything you else you guys think I need? I'm working with a 1K parts budget, if i do this now...
cya
fat lando
