my design, but not my parts
he did tell you that correct???
it's not that big of a deal as long as everything works.....we talked about it and I'm cool as long as he does not pass them off as mine, I don't want to deal with broken parts or failed installs (a few people have gotten a little hammer happy trying to get the bearings into the tube once the tube is installed....on a few installs, the tube gets tweaked ever so slightly, no big deal, just clean the ID and the bearing will go in)
Rear kt instructionsdo the tubes have one end turned down slightly?
if so, that is the end that is the end that you insert into the trailing (Pic 1)
Not included in the directions, but it helps, is once you test fit the tube so that it slides into the trailing at least halfway somewhat easy, remove the tube, spray the OD of the tube and the ID of the trailing arm with paint,
now insert the tube completly...the paint acts as a lubricant, sealer and locking compound.
if you have any questions, feel free to call me on my cell:
510.484.8700
