QUOTE(RobW @ Oct 5 2015, 05:52 AM)
I relocated the fuel pump to the front with the AA kit (my bad). Vapor lock actually did happen...
Use the SS line from CF. That's what is required for any 914 IMHO.
Rob, did you get it after you relocated the pump?
I purchased the complete tank to engine kit from Tangerine with the relocation to frunk option. I got the long adapter. The whole kit is super nice and looks very well made. I plan to install this later in fall when the car goes up on jack stands for the winter.
QUOTE(Racer Chris @ Oct 5 2015, 08:39 AM)
QUOTE(dangrouche @ Oct 5 2015, 11:03 AM)
QUOTE(dangerranger01 @ Jul 19 2015, 05:59 PM)
So when would you use the adapter? Are the lines different sized when you use another fuel pump, or when you don't have a relocated pump? I'm just confused on that part...I guess when I call tomorrow or later this week, Chris will clear it up...
that adaptor is for transitioning to the OEM cube fuel filter, (which has two different sized inlet and outlets); its for the stock location, under the hell hole
People run into additional uses for the adapters depending on other fuel system modifications being done/considered.
A recent sale included one u-bend adapter and one 90 degree adapter so the owner could install a 9.5mm tunnel line in a '76 model 914 with stock FI engine, and have the option to convert his engine to a big six without replacing the tunnel line again.
I guess I never thought about that. I may plan to do a swap in teh future, didn't think of installing larger lines in the tunnel. How much does that really matter? Isn't it all about the liter/hr of the pump, not so much on the fuel line diameter? Chris, can you school me on this?
