LowBridge
Jan 8 2016, 12:40 PM
found this company (
My Webpage) just around the corner from my home and they are cleaning the tank now for $200-$250 depending on how many times they need to dip it and inspect it.
they also offer a re-coating option ($450 and this would include the removal also) with this product (
My Webpage), so this where I'm on the fence again as to if I should or should not. Personally I'm thinking that I'm not going to get it re-coated, but I figured I throw it out here for some community feedback.
r_towle
May 24 2016, 06:44 PM
Hi,
Just up the road here n Dunstable.
I have a few spares if you need stuff.
We lived n lunenburg about 20 years ago....
Missed this thread, but
Rich
LowBridge
May 25 2016, 05:44 AM
QUOTE(r_towle @ May 24 2016, 08:44 PM)
Hi,
Rich
sweet someone close I have a ton of questions about local shops for getting a few things done. maybe we can get together for a few
. My son and I just spent Saturday up at Devens running the NER PCA autoX event with the car and had a great time.
John
LowBridge
Nov 12 2017, 03:48 PM
So we are heading down the the Richmond Transmission class with DrEvil and decided to pull the engine and not just the transmission. I figured we could clean up the engine area and get to a few items that need attention.
Well the engine is out and the transmission is ready for Richmond, one of the things I wanted to look at was the oil cooler because this summer was hotter than normal and the engine was running warmer than it did last year.
I removed the tins and look at what I found.. no cooling flaps to include all the needed parts to complete this cooling process.
Question now is do I really need it (I feel I do) but I wanted to get the opinion of the community before I start looking for a few hundred dollars worth of parts because I'm going to need it all.
Dave_Darling
Nov 12 2017, 03:51 PM
Yes, you need them. Find whomever built the motor and slap them for omitting the flaps.
--DD
76-914
Nov 13 2017, 10:31 AM
While your in there you may want to replace the seal on the oil cooler. I noticed that 914rubber is supplying those now.
LowBridge
Nov 16 2017, 10:07 AM
QUOTE(76-914 @ Nov 13 2017, 11:31 AM)
good idea.. thank you
LowBridge
Nov 16 2017, 10:08 AM
QUOTE(Dave_Darling @ Nov 12 2017, 04:51 PM)
--DD
well.. off the the classified area to post a WTB
LowBridge
Jan 13 2018, 02:47 PM
well the odometer is finally fixed and I have replaced all the lens with glass for PP. It's a good winter project. The red circle is the gear that was slipping and following the links on fixing this is good to go now..
LowBridge
Jan 13 2018, 02:49 PM
Also went down to VA and attended the DrEvil class and that was a ton of fun.
r_towle
Jan 13 2018, 02:53 PM
hows the project going?
Rich
LowBridge
Jan 13 2018, 03:06 PM
really good.. I only have a few more rubber items to replace in the engine bay area and I'm going to also install CFR's firewall shifter bushing along with upgrading the fuel lines in the bay to a braided lines with AN fittings (did the tunnel lines last winter), new clutch cable, new inboard CV's (need to order these and the bushing from CFR along with a few other items).
on track for spring at this point...
did you get your heater installed?
LowBridge
Apr 22 2018, 05:23 PM
finished almost all of the winter projects and it's back on the road again as of today.. long winters suck for driving but are fantastic for procastinators like me with projects
