Am I missing anything?
914/6 Clutch package (TO bearing, pressure plate, 6 spring clutch disk)
914/6 flywheel, 5 bolts and metal crush gasket
pilot bearing and felt
Flywheel o-ring
muffler gaskets, 2
914/6 rear main seal
914/6 (901) input shaft seal
914/6 (901) output shaft seals, 2 each
914/6 (901) speedo drive seal and o-ring
914/6 (901) cover plate gasket
Valve adjustment kit
And because I have DWD:
914/6 headers 1 5/8th
914/6 exhaust/head bolts
Front Koni Yellow Sports
Rear Koni Yellow Sports
Front suspension bushings
Rear suspension bushings
