QUOTE(carphappy @ Sep 9 2015, 11:39 AM)
QUOTE(TheBabyBadger @ Sep 9 2015, 01:56 PM)
QUOTE(carphappy @ Sep 9 2015, 09:55 AM)
QUOTE(Chris H. @ Sep 9 2015, 11:40 AM)
So are you using that stock temp gauge ? The combo gauge to the left of the tach? Oil temp or water temp?
i am using the stock temp gauge as an oil temp gauge. i installed an electric sending unit in the oil pan and hooked it up to the existing wire. on hot days it moves beyond vertical but it has never reached the red zone. i am thinking that it is relatively accurate. i made the center console, it holds the oil pressure, water temp, boost, and afr gauges.
Awesome build! Love the set up. Venting through the floor? Wheel wells? Would love to see more pics. I run the same kit on my car.
when deciding where the warm air would go from the radiator i looked at several options, some people have vented out the hood (did not like how that looked), most people cut holes in the wheel wells and add a wire mesh (i think that a fair amount of road debris would end up in the front boot), and some cut a big rectangle in the floor. i ended up cutting a small rectangle and creating an additional vent slat. the rectangle makes it easy to plumb coolant to and from the radiator, and the additional vent hopefully helps with air flow. it doesn't look as bad as it does in the pictures and water temps only occasionally rise high enough to turn the electric fans on.
I'll have to post some pics of my radiator progress. I'm still debating. I consider the hole in the floor but I just don't know. The wheel wells seems okay, with a tight mesh nothing "should get int, I was going to run the same mesh across the floor, just in case, to drain any type of water, etc.
The vented hood is a little good, but I was going to louvre it so it looked bad ass, or add a C7 style vent in carbon so it looked cooler. So many options!!!
I'll start a new thread and get some pics up soon. Awesome car!
