I pulled the axles off my car recently and found the CV joints were welded onto the ends of the axles. My car is a 6 conversion, and the whole rear axle assembly has been modified to take 100mm diameter 6 bolt type 4 CV joints - which I now know are also 944 cv joints.
Having done some research and spoken to Chris at Tangerine I've learned this set up, and the welding, isn't the best way to do it, but isn't unusual with custom axles, so can stay on the car for now. However, I know that at some point I will probably break a CV joint, so I'm trying to plan ahead to find a better alternative.
The type 4 joints are 33 spline, the same as type 1 CV joints, so a 914 axle will fit, but the centers are 28mm wide compared to 24mm on the type 1 joint. I've never seen how a 914 axle is put together, but I'm assuming the extra 4mm means the groove for the circlip is covered and that's why whoever made mine couldn't just plug n play 914 axles.
So, if I stick with 944 CV joints, I'm wondering what my options for axles are, if any? Is it possible to get the splined section on a 914 axle machined longer so the circlip channel is usable?
Or get the circlip channel enlargened to accommodate the extra 4mm thickness of the type 4 CV joint? This would of course extend the length of the complete axle assembly by 8mm - is matching the exact original 914 axle length critical?
I appreciate there may be some dumb questions/ideas in here, I'm no engineer
John
