Bob,
I know you are a bit down right now, but remember.... these are 40+ year old cars and we have definitely advanced tire technology since then. That means the extra load is going to break things.
As for your 914s hating you... Join the club buddy.
My six is down with a crack in the left engine case. It runs great, but I cant' drive it because it leaves a huge oil slick and will run out of oil in 30 minutes .... 12quarts.
If anyone has a lead on one, I am looking for a 964 engine to put in my car (can you say 4.0L flat six?)
Betty's 914 was making a weird noise. I got a second opinion from Ed Mayo, and he agreed with what I was thinking. The rivets in the cam gear had come loose. So I dropped her motor, and pulled the oil pump. You could see the rivets had come loose, the holes were elongated so much you can see them past the rivet heads. So I split the case. Now i found that the intake lobes on the cam had 3.5mm different lifts, and the exhaust lobes had 1.5mm difference in lift.
The new Raby 9590 cam kit is sitting in the living room (It's good to have a 914 loving wife), and today I get to spend cleaning dirty engine parts in the parts washer. Tomorrow after I get home from work I will be working on her engine.
It probably won't get put back in until after Rennsport. But I keep in mind things like looking over at you and Nadine in Huey at the end of the first tour on the Dragon last year, and saying "Damn that was fun!". That keeps me going.
(Yes, I work Sundays all the f*cking time, plus 60+ hour weeks. That's why I have not been on here lately)
And I am going to learn from you. I am getting a set of the control arm stiffening plates for Igor before I go to the 4.0L motor.
If I was in your position, I would have dropped the motor out of Huey and put it in Papa Smurf to take to Okteenerfest. Just put Huey's license plate on Papa Smurf and drive.
Or you could have gone to a local place that wraps cars and had a wrap done for the 911 that looked like Huey......
