bdstone914
Apr 2 2019, 08:43 AM
QUOTE(Spoke @ Apr 1 2019, 03:00 PM)
QUOTE(Chi-town @ Apr 1 2019, 04:11 PM)
Easiest way
It could be so that this wire is found on the lugs on the fuse panel for fuse 1 or 2. Easily removed and with a pigtail with male spade on one side and ring terminal on the other side, the modification "should" be an easy update. The fogs would be on then with low or high beam.
Talking to Bruce today, I realized my 930 with LED headlights has the same connections as the 914. I haven't tried the foglights with the LED headlights to see if they still work. Will have to try it this weekend.
@Chi-town @spoke @mikey914 @matty900 Dylan, ( Chi-town)
Anxious to see if it works.
Will be glad to help and document exactly how it it done.
Bruce
Spoke
Apr 2 2019, 11:20 AM
I may drop the fuse panel this weekend in my 914 to look for the white/blue foglight wire.
bdstone914
Apr 2 2019, 06:06 PM
QUOTE(Spoke @ Apr 2 2019, 10:20 AM)
@spoke @chi-town Dylan is going to try the same on a 914.
I like the option of separating the operation of the dogs from the headlights.
Still looking at best mounting for the load resitor.
Here is where I think it should go. Thick metal and air flow when the lights are up.
Spoke
Apr 6 2019, 10:34 AM
QUOTE(Spoke @ Apr 1 2019, 06:00 PM)
Confirmed today that the foglights on the 930 do work with low beams and turn off with high beams. It could be so that the LED headlights on the 930 have a different impedance than the ones on the 914.
orthobiz
Apr 6 2019, 11:00 AM
I never posted my final solution. I had the fogs wired separately so no more hi beam/lo beam woes.
Paul
FlacaProductions
Apr 6 2019, 01:13 PM
separately? you mean direct and bypassing the interconnection/relay with the hi/lo switch?
orthobiz
Apr 6 2019, 02:35 PM
QUOTE(FlacaProductions @ Apr 6 2019, 03:13 PM)
Yes, direct separate wiring. Actually Brad/Michael at 914ltd did it for me.
Paul
drem914
Apr 7 2019, 10:32 AM
QUOTE(Mikey914 @ Mar 31 2019, 11:52 AM)
The load resistor needs to be on the low beam, to trigger the relay.
Mark, I purchased the resistor from you, but am still waiting on a final wiring diagram so I know where and how to connect up. Scott said you might have that out soon?
Spoke
Apr 7 2019, 09:48 PM
I modified the headlight/foglight schematic to show where the foglight relay attaches to the high beam lights. Turns out the 914 is wired such that the white/blue wire from the foglight relay is connected directly to the spade connected to the high/low beam relay.
Spoke
Apr 7 2019, 09:52 PM
I decided to rewire the foglight to be independent of the high beams. Disconnected the battery negative cable and dropped the fuse panel.
The high/low beam relay is shown on the right side of the panel. The foglight wire is the white/blue wire. This wire will be cut and tied to ground.
Spoke
Apr 7 2019, 09:55 PM
The white/blue wire to the foglight relay is cut and crimped to about 1 foot of wire. The other end of the wire has a ring terminal crimped on.
Spoke
Apr 7 2019, 09:57 PM
The other end of the new wire is grounded on this lug. Now the foglights are independent of the high beams. With this modification , a ballast resistor will not be necessary when the headlights are LEDs.
Mikey914
Apr 7 2019, 10:18 PM
This would actually be the preferred method of install as the resistors will generate heat.
Thanks Spoke
Mikey914
Apr 7 2019, 10:19 PM
QUOTE(drem914 @ Apr 7 2019, 08:32 AM)
More than happy to take it back, Spoke’s solution is preferable.
Mark
drem914
Apr 8 2019, 09:05 AM
QUOTE(Mikey914 @ Apr 7 2019, 09:19 PM)
Mark
Thank you, I'll bundle it up and send it back. It's stlll in the orignal bag you sent it in.
Shredhead
Apr 10 2019, 12:49 PM
I wonder if this would solve the problem I have, which I really haven't tried to solve yet. Have new LED headlight bulbs. First time I tried them, High Beam, check, Low Beam, check. Can't recall if I tried the fogs, which are still incandescent (and I think one is out). Next time I tried, them, Highs worked fine, Lows... nada.
Spoke
Apr 10 2019, 04:25 PM
QUOTE(Shredhead @ Apr 10 2019, 02:49 PM)
When the lows didn't work, were the high beams still on or no lights at all?
Also was the foglight switch on or off?
FlacaProductions
Apr 10 2019, 08:37 PM
Spoke/Mark/all - thanks for spending the time to get this sorted. I'm away from my new-to-me 2.0 but this is really going to help as upon initial inspection I found that the current H4 reflectors were deteriorated and I was wondering what route I should take - stay with H4's or go LED. I really wanted to go LED but not if there was going to be collateral "damage" - can't wait to get back to the midwest where the 914 is living so I can tackle this. oh - and placing an order for Spoke's LEDs and some rubber from 914 Rubber...great resource here!!
FlacaProductions
Apr 10 2019, 08:50 PM
Should the line coming off the high/low beam relay just be capped off?
bdstone914
Apr 10 2019, 09:29 PM
QUOTE(FlacaProductions @ Apr 10 2019, 07:50 PM)
@FlacaProductions No. The solution is to remove the blue/wite wire from the fuse panel and run directly to ground.
Pictures from
@chi-town .
bdstone914
Apr 10 2019, 09:38 PM
QUOTE(FlacaProductions @ Apr 10 2019, 07:37 PM)
If you dont have fog light there are no known malfunctions.
LEDS can have some strange affects on related systems.
Was told of a user installed LED backup bulb in a Chevy truck. Caused a trans error light. They pulled the teams and went thru it and no internal problems were found. Many newer cars need a canbus to avoid erroneous errors from being generated.
Bruce
bdstone914
Apr 10 2019, 09:41 PM
QUOTE(Shredhead @ Apr 10 2019, 11:49 AM)
@Shredhead You may have a hi-low relay that is sticky.
Bruce
FlacaProductions
Apr 10 2019, 11:35 PM
well now i'm confused and i've read this over and over.
which is correct?
A: the blue/wht line from the HIGH/LOW relay gets grounded
B: the blue/wht line from the FOG LIGHT relay gets grounded
jcd914
Apr 11 2019, 12:24 AM
It is the white wire with the blue stripe from the fog light relay but as Bruce illustrates it is easier to get to it were it connects to the fuses. So pull the wire Bruce shows from the fuse panel and connect it to a ground. The fogs will then be completely separate from the high beams.
Jim
Spoke
Apr 11 2019, 03:20 AM
QUOTE(FlacaProductions @ Apr 11 2019, 01:35 AM)
which is correct?
This would be the same wire except it appears it could be physically connected at a different point.
A: On my '71 the white/blue wire was physically connected to the high beam spade connector at the high/low relay.
B: In the car pictured by Chi-Town via Bruce, this white/blue wire is shown connected to the high beam fuse on the fuse panel. Maybe a later year car?
In either case, this is the same wire and should be removed from its current position (either cut at the connector if in A: or pulled from the fuse if in B: )
Make a pigtail of about 1 foot of wire with a ring connector on one side, and on the other side either:
A: Crimp the white/blue wire cut from the high/low beam connector.
B: Crimp a male spade on and connect to the white/blue wire pulled from the fuse. Put shrink-wrap on the spade connection as to not touch any of the 12V power in the fuse panel. I would not recommend taping this off as the tape may come off and short to any of the 12V power.
The ring connector side of the wire is then connected to a local chassis point.
Shredhead
Apr 11 2019, 04:20 PM
QUOTE(bdstone914 @ Apr 10 2019, 11:41 PM)
Bruce
I was thinking that too. Going to try a new one.
Shredhead
Apr 11 2019, 04:21 PM
QUOTE(Spoke @ Apr 10 2019, 06:25 PM)
Can't remember right now. Have to check. I'd like to have the fogs on the "honor system" anyhow.
FlacaProductions
Apr 11 2019, 10:45 PM
Got it now. Crystal clear. Thanks tons.
bdstone914
Apr 12 2019, 06:24 AM
Edit:
Looking closer at the 70-71 and 72-73 diagrams I see a difference on the fog light relay ground. Only the 72-73 shows the blue - white wire to the #1 fuse.
I need to get all year diagrams.
Wire diagrams show the blue-white wire is connected to the #1 use spade fot 1970-1973 cars.
I have not checked diagrams for 74-76 cars.
Chi-town shows a 73 harness.
My bet is that all years have the wire in the same location.
@spoke @jeffbowlsby
Spoke
Apr 12 2019, 07:18 AM
These images are from my Haynes 914 Owners Workshop Manual. It shows only the "Up to 1971, USA and except-USA" cars have the white/blue wire to the foglight connected directly to the wire spade connector on the high/low headlight relay. All other years show the white/blue wire connected to Fuse 1.
It shows basically 3 different drawings of 2 configurations:
1) "Up to 1971, USA and except-USA" White/Blue wire connected at High/Low Relay.
2) "1972, 1973, USA and except-USA" White/Blue wire connected to Fuse 1.
3) "1974, 1975, USA and except-USA" White/Blue wire connected to Fuse 1.
Here is "Up to 1971, USA and except-USA" White/Blue wire connected at High/Low Relay. Foglight relay is #53; Headlight switch is #27. Note wire on pin 85 on #53 foglight relay connecting directly to the spade on pin F on #27 high/low headlight relay.
Spoke
Apr 12 2019, 07:22 AM
2) "1972, 1973, USA and except-USA" White/Blue wire connected to Fuse 1. Foglight relay is #53; Headlight switch is #27. Note wire on pin 85 on #53 foglight relay connecting to Fuse 1.
Spoke
Apr 12 2019, 07:25 AM
3) "1974, 1975, USA and except-USA" White/Blue wire connected to Fuse 1. Foglight relay is J12. Note wire on pin 86 on J12 foglight relay connecting to Fuse 1.
Also note that in previous years, it was pin 85 used as the switched ground for the foglight relay. Here it is pin 86. For those questioning whether a relay coil could be powered one way or another, looks like Porsche answered that question...
Biggles
Apr 12 2019, 11:58 AM
Great info!
I’ve got this issue too on my ‘70 -6 since installing LED headlights
Haven’t looked at the fuse panel, but will this be the same as a -4?
Thanks
QUOTE(Spoke @ Apr 12 2019, 02:18 PM)
Spoke
Apr 12 2019, 01:43 PM
QUOTE(Biggles @ Apr 12 2019, 01:58 PM)
Great info!
Thanks
Not sure about the 70/6 wiring. However it is likely you'll find that wire either on the F pin on the high/low headlight relay or on the F1 fuse. I think you'll find the wire on the F pin. It looks like they changed the physical connection to the F1 fuse as the model years went onward past 1971.
FlacaProductions
May 23 2019, 08:16 PM
@bdstone914 @Spoke and
@chi-town - thanks so much for this. Finally got around to installing the LED headlights (thanks
@Mikey914 ) and "ground-the-wht/blu-llne" mod worked perfectly. I snapped a tab on the headlight retaining ring during the swap and may be getting one locally but if not, i'll reach out to you chi-town and get one as well as the ss screws. that's the final step for proper aiming. Huge thank you to all.
Chi-town
May 23 2019, 09:32 PM
@FlacaProductions happy to help, let me know on the headlight stuff, I have a bunch
FlacaProductions
May 24 2019, 08:32 AM
PM sent...thanks!
QUOTE(Chi-town @ May 23 2019, 08:32 PM)
malcolm2
Oct 31 2019, 02:02 PM
malcolm2
Oct 31 2019, 06:05 PM
QUOTE(malcolm2 @ Oct 31 2019, 03:02 PM)
Am I getting this thread right? You guys only did the wire mod on the fog light relay above? Grounding the wire on fuse 1?
NOT the Blk/blu wire mod between headlight switch and the fog light switch
AND NOT the add a new wire from 8/9 fuse to Fog switch term 15?
You
DID NOT do those 2 and you still have your Fogs on their own and they work anytime the key is on???
FlacaProductions
Oct 31 2019, 06:15 PM
I just did the grounding wire - nothing else other than the Spoke relay.
NO - my fogs only work when the parking lights are on. (or when the headlights are on, obviously.)
malcolm2
Oct 31 2019, 07:06 PM
QUOTE(FlacaProductions @ Oct 31 2019, 07:15 PM)
I figured is was easy to do and I could do more. So I did as mentioned. Pull the wht/blu wire from fuse 1..... make a pig tail with a female spade on one end and a ring connector on the other.... mate the wht/blu and the female on the pig tail.... attach the ring connector to a chassis bolt.
However, my fogs don't work exactly as you stated. They only work with the headlights on. But now they stay on when the headlights are on LOW or HIGH.
Daytime driving light feature does not interest me at the moment. Forgot to check the indicator light in the switch knob..... But I did notice that my small green FOG indicator light in my speedo did not illuminate. Could be the bulb. I have backdated my gauges to silver dot. The 120 mph speedo has a fog indicator that used to work.
Thanks for letting me join in this older thread.
FlacaProductions
Oct 31 2019, 07:23 PM
You might need
@Spoke EP26 relay so it all plays nice with the LEDs
gereed75
Jun 4 2020, 09:49 PM
Resurrecting an older thread here to add a bit more info to close the loop for six guys.
According to my 70 914-6 wiring diagrams, the two white/blu wires are connected together at the fuse terminal 1. One goes to the instrument lights and one to the headlight relay. I will be doing the grounding of the relay wht/blu tomorrow and hopefully cure my wonky fog/LED headlight thing
Incidentally I have three different 914-6 wiring diagrams - the Zapf diagram, a German diagram of unknown origin, and a German diagram I always thought was out of the factory manual. Each has it own individual characteristics/ uses.
The two German ones show what we know as fogs to be called “additional high beams” . They show no fog light switch at all. I suspect they are activated via the headlight relay. The factory diagram is easiest to use for tracing colors (very clear color labeling). The other German one has no color labels but does show each switch or connector terminal number. The Zapf calls the second set of lights “fogs” and shows a switch. The Zapf is very difficult to trace wires on in some places, they all blend together. I have found at least one wire color to be wrong.
raynekat
Feb 12 2021, 12:21 AM
QUOTE(904svo @ Sep 21 2015, 07:02 PM)
If you want that option, take the Blue/white wire and put it to ground instead of wiring it to #30 , forget about the rest of the wiring and relay.
Started to have the same wonky high beam/fog light issue a year after installing my 914 Rubber LED bulbs.
At first, everything worked correctly.
Just recently, no fogs when I pull the fog light switch and instead the high beams come on.
So I just took the white/blue wire from the fog light relay and removed it from the other relay and went directly to ground with it.
Everything works the way I want it now.
This change makes the fogs independent of the headlight/high beam switches.
Can run the fogs on their own or with any combination of low/high beams.
Simple.
One thing I noticed was I had a couple of bad relays.
I think somehow the LED headlights are back feeding power into this fog light relay and frying them.
Had two bad ones I was trying to get working.
Bench tested them and both were inoperative.
Made the wiring changes above, and inserted new relay and was back in business.
JeffBowlsby
Feb 23 2021, 07:32 PM
QUOTE(raynekat @ Feb 11 2021, 10:21 PM)
Simple.
Was cutting of any wire needed for this mod? The way it is described you just relocated an existing push-on connector.
And what is the 'other' relay mentioned?
@raynekat
raynekat
Feb 23 2021, 09:39 PM
Bruce, when I mentioned other relays, I meant the following.
The 1st couple of relays I had in my spare parts box to replace the fog light relay were all bad. Finally on the 3rd try, that relay worked. When I tested the previously tried relays, they all tested bad.
So not really other relay locations if that's what you're thinking. All the same fog light relay socket.
On my 71 wiring harness, the white with blue stripe wire at terminal 85 on the fog light relay goes over and joins up with another white wire. At that point both wires are terminated jointly in a male spade that goes to terminal 56 on the "combination" relay. It is here, where I cut the white with blue wire separate from the white wire. At this point, I could just take the white with blue stripe directly to ground.
Hope that's clear.
The white with blue stripe wire that goes to the combination relay relies on you turning on the high beams. At that point, terminal 56 on the "combination" relay affectively gets grounded. With LED headlights, for some reason this does not work anymore and strange things happen.
QUOTE(JeffBowlsby @ Feb 23 2021, 05:32 PM)
@raynekat
Spoke
Feb 24 2021, 05:33 AM
QUOTE(raynekat @ Feb 23 2021, 10:39 PM)
@raynekat The fogs on my 914 were not coming on. Turns out the relay had oxidized and was not making contact. I could hear the click of the relay pulling in but no contact. I cut the case open with my Dremel, cleaned the contacts and it works fine now.
Do your bad relays click when powered? Likely the contacts need cleaned and filed or sandpapered to bring them back to life.
raynekat
Feb 25 2021, 09:24 PM
QUOTE(Spoke @ Feb 24 2021, 03:33 AM)
Likely could have been that. Had plenty of spare relays to plug in, so just found one that worked. I've had much better luck with the old school aluminum case relays than the newer black plastic ones, but they are more difficult to find.
Feb 25 2021, 09:31 PM
QUOTE(raynekat @ Feb 25 2021, 10:24 PM)
Click to view attachmentI had a couple on my '70.
abes914
Jun 18 2021, 08:08 PM
I’ve been chasing the ghost of electrics for so so long ever since I converted to led lights all around. I thought I fixed them and then it came back. This is fixed it finally! Thank you 914world. So much geniuses here.
If I may suggest to maybe copy/move this in the classic section of the world?
