QUOTE(rgalla9146 @ Sep 19 2015, 10:32 AM)
QUOTE(Mark Henry @ Sep 18 2015, 12:52 PM)
Turbo covers are heavy, you likely could take the fins right off. Mine are also shaved down to the top of the stud bosses, about 1/4" of fin left.
Mmmmmm..... twin plug !
Is it difficult to remove the #2 plug connector ?
I just tried it
It's tight, you have to sneak it out, but I didn't have to force it
QUOTE(porschetub @ Sep 19 2015, 01:23 AM)
Yea but my point was that you mill the fins off and that's half of the reason gone to buy them.
Dirt cheap
my pricing came back as up to $230 each new or $200-300 used hardly dirt cheap,but they used to be.
Personally I would rather speed the money on a good set of engine compartment seals and keep my engine clean underneath than spend this kind of money,there are a lot of good aftermarket gaskets out there to sort this issue with the stock covers also.
Fairs fair but your comparison between between a T1 and a 911 isn't really valid,the 911 motor in a 914 needs all the cooling it can get and generates a lot of oil temp.
Well I admit I haven't needed to buy parts for almost 3 years and I know in that time prices have exploded, but you used to see good used SC covers on the bird for $30-40 a pair. The SC cover looks just like the early mag covers but are heavier and made out of aluminum.
As far as the type one comparison, IMHO is a good comparison it's aircooled and in high performance trim they have all kinds of heat issues. It's all about surface area and air flow, do you really think 4 little fins in a hot area is going to make a huge difference? My 2.0 berg engine running 8 quarts of oil and the added surface area of the sump still over heated, till I put 2" standoffs on the decklid increasing airflow. Oil has a real piss poor heat transfer rate.
The only way fins on the cover will make a noticeable difference is if each cover has ten 3" fins. BTW this as been done by a guy on the bird.
To me good engine seals, etc., is super important on all aircooleds so I totally agree with that statement.
Airflow, engine seals, proper tune and/or a cooler will do way more than a couple of little fins.
