QUOTE(pete000 @ Oct 6 2015, 01:26 AM)
I just installed Pertronix kit in my 74 1.8 but was considering the Mallory set up.
I would be interested on hearing more about your experiences as you tune it.
Why did you not go with a vacuum advance unit? I have read true mechanical advance is not good for typical street use, but I have also read that
the 74 914 1.8 did not use vacuum advance only retard. (A Hot topic of debate)
I had run my Petronix for about 1 month now,already changed injectors connectors,plugs,wires coil.
The problem was It felt like I had no advance when running.
Car was just slow very little power off the line or climbing hills.
I have one line from my throttle body to my 1 advance line on my distributor,and it made no difference plugging it in or leaving it unplugged when timing car,or running the car.
So from all the reading I did, it sounded like the Unilite was the way to go.
And it is.
When I say the car has more power,I am guessing the advance is working like its supposed to Now.
What used to take 1/2 throttle to go through the gears now takes 1/4 gas.
I have it timed off the red mark on the fan.
On the 1.8L this is the 7.5 degree mark.
Anyway if you can find one get one.
I tried to buy one from Aircooled but I think they thought they could not get me one.
But they did eventually find me one,but had bought one off ebay by then.
When I bought the car 3 months ago I had no idea it could be so much more fun to drive than when I bought it.
Car is running like a top,besides the oil leaks I could not be more happy.
I take Zero credit for any of it though,I did the labor but everyone hear told me how to do it.
So Thanks .
