alright then, let's repost that stuff here, seems like no one clicks on links anymore these days ...
run them from the front trunk through the little passage tunnel inside the pass. side footwell, from there, next to the pass-side long to the back, then through the firewall ...
have the lines enter the small tunnel on the front firewall, route through tunnel ...
tunnel exits into the pass. footwell, from there run alongside the long and then through back firewall ...
btw. you can run the oil lines from there straight into the long without going through the top heater outlet.
there is a access hole in the side of the long where the blue arrow is pointed, it's covered with a tar-patch. this will give you easy access to the long tunnel.
that way, you minimize the length of oil-line inside the cabin (they DO radiate heat) ...
Andy
