Allan
Mar 10 2005, 12:33 PM
I bought a speedo drive seal from GPR last week and it looks like the shifter seal only smaller. The haynes manual shows an 0-ring. Does anyone know which is correct before I try to replace it. The part number I have for the new one from GPR is 999.113.036.50.
Here is a crappy pic.
Allan
Mar 10 2005, 06:24 PM
phantom914
Mar 10 2005, 06:31 PM
There are two seals: an O-ring that seals the drive housing to the tranny case, which you can see when you remove the bolt and pull the drive out of the tranny, and a seal (which you already have) that seals the rotating shaft. You can see the seal when you unscrew the bottom half of the drive housing from the top half.
I can look up the number for the O-ring when I get home in a couple of hours. I know Pelican has the O-ring, but I don't see it on their site. It will come up if the Porsche part number is typed in though.
Andrew
phantom914
Mar 10 2005, 08:35 PM
O.K. The O-ring part number is 999.701.084.50
Pelican should have them. That's where I got mine from.
Andrew
Trekkor
Mar 10 2005, 09:09 PM
I don't remember any seal but the o-ring on the speedo drive.
KT
Allan
Mar 10 2005, 09:11 PM
Maybe it goes in here?
phantom914
Mar 10 2005, 09:30 PM
Yes. The seal you showed goes there. Unthread the two halves and pull the shaft out.
Andrew
swood
Mar 10 2005, 10:17 PM
Mine seems to be a bit loose at that point. Could it be coming unthreaded or the seal going bad??
Bruce Allert
Mar 22 2005, 11:36 PM
OK, so... if those 2 seals are replaced will it stop the leak?
Swood... did it work??? no more leak'n???
........b
Allan
Mar 23 2005, 06:57 AM
What I saw when I pulled it apart was that you can't replace the internal seal unless the machined casing can be split open.
