I wasn't paying attention when I pulled my tank to put in the SS lines and need to know which fitting is feed and which is return. Also, is the return line under the same pressure as the feed?
Thanks
QUOTE (jr91472 @ Mar 11 2005, 01:55 PM) |
the small washers that go on the fittings at the bottom of the tank, are NLA from Porsche. |
QUOTE (Headrage @ Mar 11 2005, 02:19 PM) | ||
I didn't see any washers when I took it apart. I don't think it was leaking either. |
QUOTE (jr91472 @ Mar 11 2005, 07:58 PM) |
I think the factory ones were made of fiber or some such. Maybe you can re-use them. Since you took your tank to a radiator shop, they might have something as well. I found my notes from when I spoke with the Porsche dealer. He gave me the deminsions for the washers: big one: 16mm outside dia. / 10mm inside dia. smaller one: 16mm outside dia. / 8mm inside dia. |
