QUOTE(mgp4591 @ Jan 29 2016, 11:14 PM)
Any thought to a circuit breaker on either end of your power cable? A lot of high end sound systems run them to protect the system from both sides of the main power cable, you don't have to replace them when a mistake is made and they're great for theft deterrence. And they don't cost very much either!
I'm finding lots of options with circuit breakers and thinking this is worth trying
because my battery cable is so heavy, I'm struggling to find any type of fuse block or circuit breaker with a large post.
I hate the idea of running a small gauge wire to the fuse block and then jumping to a 3/4 inch welding cable for the run to the front trunk
most of the aftermarket options I find have very small mounting posts for the wire or in line fuse... along the lines of a 1/4 inch post....
I see the a stock mitsubishi part that bolts directly onto a battery post, and then has a new battery post size mount for the existing battery cable
but it is a 120 amp fuse and 15+$ to replace... I don't anticipate wanting 120amps.... and its not adjustable as the fusible link is built into the mounting block and not replaceable.
so I think i'll buy a circuit breaker of 30 or 50amps and with the largest mounting post I can find and see what happens.
I wish they made a circuit breaker with a standard battery post size in/out
brant
